disassemble cigarette lighter
Old Jan 19, 2021 | 06:34 AM
Jomiltom's Avatar
Default disassemble cigarette lighter
Good morning. I need to disassemble the cigarette lighter and I've been looking in the finder and can't find anything.
Someone could explain to me how to disassemble it. I don't want to break anything
Old Jan 19, 2021 | 07:33 AM
Bill Mack's Avatar
More information would be helpful to provide a useful answer. Why are you taking the cigar lighter apart? Do you need to remove the entire cigar lighter assembly, or something else?
To remove just the cover of the assembly, see post #279 in this thread.
If you need to take the entire assembly out, there is a procedure starting at page 3369 of the Service Manual (procedure designated as 76.25.01) that involves the removal of the center console. This may be more than you need to do.
I hope this helps getting you started.
Old Jan 19, 2021 | 07:50 AM
Jomiltom's Avatar
What I need is to be able to disassemble the cigarette lighter to replace it since it is damaged. Anyway I appreciate the information you have provided me
Old Jan 19, 2021 | 08:04 AM
Bill Mack's Avatar
The best way to show appreciation is to click the button on my post. Thanks and good luck!
Old Jan 19, 2021 | 08:55 AM
MarkyUK's Avatar
Buy a new one, they aren't expensive, ask your dealer who should be able to post it to you for around €25
If you can't afford that you've bought the wrong car
Old Jan 19, 2021 | 11:03 AM
Cee Jay's Avatar
The outer housing threads off from the back. That's all.
Old Jan 19, 2021 | 02:20 PM
Jomiltom's Avatar
Thank you. In the end I was able to disassemble it, now install the new one and reassemble everything.
Regards.
Old Apr 10, 2021 | 06:33 PM
LockNumber25's Avatar
I'd like to tap into the supply to the lighter to power my RPi. Is it possible to pull the lighter assembly out from the top so I can get to the wires feeding it underneath?
Thanks.
Old Apr 10, 2021 | 07:03 PM
Stuart S's Avatar
Thanks.
What's an RPi? Any of these?
Note that the cigar lighter circuit is switched, which means that there is no electric power to that socket when the engine is off and Convenience Mode has timed out and shut off that circuit. If your RPi needs to be powered when the car is locked (like an alarm system autodialer), then the cigar lighter socket might not work. I presume that an attempted break-in that triggers the alarm would activate Convenience Mode and provide power to the cigar lighter circuit, but I'm not sure.
Old Apr 10, 2021 | 07:08 PM
Sorry, Raspberry Pi. Switched power is what I'm after. Thanks for the info.
mattyhurd
Nov 6, 2021 06:38 PM
Salu498
Jul 20, 2021 02:34 PM
Jul 1, 2012 09:25 PM
Abacab
May 30, 2011 07:32 PM
jonbugh
Oct 21, 2008 04:11 PM
