DIY Coolant flush
Old Sep 18, 2019 | 04:36 PM
auchman's Avatar
Default DIY Coolant flush
What components need to be removed in order to do a coolant change. Does radiator need to be drained, or just hoses. 2011 xk
Old Sep 18, 2019 | 04:46 PM
Sean W's Avatar
Here's a link to the workshop service manual you can download @ no cost.
http://www.jagrepair.com/images/Auto...XKworkshop.pdf
Old Sep 19, 2019 | 03:43 PM
auchman's Avatar
Thank you -the manual was very helpful. I am stuck trying to locate a drain plug shown on page 1197. I have no idea where the picture is showing. Thanks for any help!
Old Sep 19, 2019 | 05:26 PM
Sean W's Avatar
Try posting a snapshot of the page or the image on the page
Old Sep 20, 2019 | 07:34 AM
auchman's Avatar
Old Sep 20, 2019 | 09:38 PM
Patrick Wong's Avatar
If you are referring to the purple drain plug, that is on the engine block, driver's side (LHD cars), near the exhaust pipe leading to the catalytic converter.
If you are referring to the blue drain plug, that is below the radiator.
Those colors are to highlight the drain plugs in the photos, don't expect the actual parts to have those colors.
I would say it is sufficient to drain the coolant from the radiator and forget having to raise up the car sufficiently to get under the engine so you can remove the purple drain plug.
Old Sep 20, 2019 | 10:28 PM
u102768's Avatar
I would agree with Patrick. I undid the 'blue' drain plug when I needed to drop the coolant level sufficiently to change a hose. I was able to access it without jacking the car up as well.
Old Sep 21, 2019 | 01:49 PM
auchman's Avatar
Thanks- I found the purple plug, and it is in an impossible location, with a not available to me tool needed for removal. Radiator flush looks good!
Old Sep 21, 2019 | 02:02 PM
Sean W's Avatar
If you use a vacuum kit, you only need to access the blue plug and you will get a complete drain and fill. Most auto parts stores rent them and return all your money when you return the kit. They will even show you how to connect it and use it.
Old Sep 22, 2019 | 03:24 PM
Thorsen's Avatar
Sean,
If you only drain through the blue plug (bottom of the radiator), how can you do a complete drain if there is still coolant left in the block?
Also, thanks for the tip about the vacuum kit. I had never seen one of those before. That looks even better than
the coolant funnel the coolant funnel
I bought a few years back.
Thomas
Old Sep 22, 2019 | 04:37 PM
Sean W's Avatar
I meant to say partial, not complete in that sentence. there are 3 procedures in the manual. only one is a complete drain and you need to access that plug. The other two are partial drain. The vacuum eliminate the fussing with the expansion tank.
Old Sep 22, 2019 | 05:48 PM
Thorsen's Avatar
Thanks. I'm about to do this soon and was hoping there was an easy/easier way than draining the block.
Old Sep 22, 2019 | 07:09 PM
Sean W's Avatar
I suppose you could do a drain and fill using a vacuum fill kit, drive around, repeat a few times and you'd get something close to a full flush without draining the block.
wrair
Jan 17, 2024 01:55 PM
Americain
Aug 15, 2016 12:50 PM
Kidpakman
Oct 28, 2012 02:33 PM
Noxparadise
Jun 5, 2012 06:03 PM
yeldogt
Jul 30, 2010 01:16 PM
