DIY spark plug change, 5.0 S/C
Old May 6, 2020 | 02:27 PM
George05's Avatar
Good man got their in the end with skin intact lol . on subject of oil. I and my indie always used 5w20 indie has a xfrs 15 reg and use it in his and a couple of workers who work their drive xfr they still use it to. been through this subject before with Stuart . Every thread i have seen , read on this forum regarding engine problems in xfr , xkrs, xjr, and ftyp[es all have used 0w20 stick to 5w20 and change it twice per year your engine will last for ever
Old May 6, 2020 | 03:43 PM
Cee Jay's Avatar
In truth, was it worth it to do it yourself? My indie charges $380 all-in to change all eight plugs.
Old May 6, 2020 | 06:58 PM
guy's Avatar
guy
my dealer did it for (slightly) less ;-)
Old May 7, 2020 | 09:23 AM
8bit's Avatar
Not quite with skin intact, the cut on my right index finger is still healing As for oil, I take your point but I'll personally stick to what Jaguar tell me is the right stuff to use, thanks anyway.
I guess that depends on how much you'd miss the difference between that $380 and the cost of a set of plugs. Also how patient and handy you are with car DIY. If I had to do it again I probably would, now I know how to get at them and I have low profile wrenches to get at the coilpack bolts on the LHS.
Old May 7, 2020 | 02:24 PM
George05's Avatar
My local main dealer s price for just a oil and filter price was £265 plus Vat . my local indy charged £185 plus vat , Diy £90
Old May 8, 2020 | 05:46 PM
8bit's Avatar
Had a look at the old plugs, the tips all look about the same colour and that appears to be OK so I guess no cause for concern with the engine. The two on the left came from the rear-most cylinders, bit darker discolouration round the threads there but I guess they're closest to the oil drains for the PCV system. The fifth one from the left has a nasty crack on it but that one took a lot of force to remove so probably cracked on removal.
DIY spark plug change, 5.0 S/C-jufwzpo.jpg
DIY spark plug change, 5.0 S/C-mshm36s.jpg
Old May 8, 2020 | 05:57 PM
George05's Avatar
Look good
Old May 9, 2020 | 03:45 AM
  #28
guy's Avatar
guy
@8bit . How many miles on those plugs? They look pretty good.
cheers!
Old May 9, 2020 | 01:34 PM
8bit's Avatar
Can't remember exactly (I generally have the DIS display to show remaining range) but a little under 60k miles, certainly no more than that.
Old Aug 5, 2020 | 06:28 PM
  #30
CSmith22's Avatar
Default Tips?
Posted in error
Old Sep 20, 2020 | 02:18 AM
  #31
MarkyUK's Avatar
I bought my plugs ( ILKAR7C10) for £55 on the Bay of E delivered last year, my Indy has advised they will change them for me when they take the SC off (for snout and oil) for half an hours labour, so £40 inc VAT. So job done for less than £100/$120
I have changed plugs/coils/points on previous cars but 8's experience means it's probably not within my capability now.
Now to ask them about a catch can install cost!
Old Sep 20, 2020 | 07:32 AM
  #32
jahummer's Avatar
For the DIYer’s with 5 litre motors, did you follow the instructions for aligning the ground electrode? Seems they all must face a certain direction for best performance.
Old Sep 24, 2020 | 03:38 AM
  #33
8bit's Avatar
I wasn't aware of any instructions like that, can you share a link please?
Old Sep 24, 2020 | 06:58 AM
  #34
jahummer's Avatar
It’s in the workshop book. I’ll find and post.
EDIT:
The threads for the spark plugs are machined at a precise start point to ensure that each spark plug is orientated in
the cylinder correctly. The benefits of this are optimum spark plug intrusion into the combustion chamber to improve
combustion, idle stability, dilution tolerance and spark plug durability. The spark plug must be tightened to the
specified torque to ensure the correct orientation.
I can't find the bloody instructions at the moment but I recall it was something like tighten to 20Nm and then one additional quarter turn to align the orientation.
Old Sep 26, 2020 | 06:37 PM
  #35
pk4144's Avatar
Wow. I haven't changed a set of plugs in ages-- but those look fine to me! They'd go into a coffee can with a little solvent and then a lite wire brush, and good to go.
And from what's described here, I'm not gonna DIY that job...
Old Oct 15, 2020 | 08:45 AM
  #36
Aprilia2012's Avatar
I am having trouble finding a post on how to change the Super charger oil on a 5.0 XKR 2011. Can you help? Dennis
Old Oct 15, 2020 | 05:11 PM
  #37
MarkyUK's Avatar
Dennis hiwz abiut you use the search facility of the forum as opposed to hijacking an unassociated thread?
Apologies in advance if youve never used an Internet car forum before
Old Oct 16, 2020 | 06:30 PM
  #38
George05's Avatar
Sorry for hijacking this thread but guy is new and only want to help . Hi Aprilia2012 . Try using the forum search thing at top right corner or use google. Simply put in , how to change the supercharged oil in a jaguar xkr 5l car and it should show you the link with photos how to , not easy but good luck and peserveranse you will get their . George . Ps I am not longer into car forums due to key board warriors who think they know better but can't do a simple service and only want to argue black and white . Get a life
JX350
Nov 6, 2018 09:53 AM
AndrewG
Nov 15, 2017 03:44 AM
Supercharged Jag
May 24, 2017 01:59 PM
Rique
Apr 11, 2015 02:31 PM
x-typeandbeyond
Aug 20, 2009 09:22 PM
