Door latch feels sloppy and harsh
Old Jul 25, 2019 | 05:39 PM
Reverend Sam's Avatar
Default Door latch feels sloppy and harsh
Cliff's Notes version: The door latches on both doors are harsh and sloppy. Is this normal?
Long version: I've fixed the major issues, now I'm down to working out all of the piddly little issues with the car. Minor things like door latches. When I pull on my door handles it seems like it takes too much effort to get the latch to disengage, then it suddenly pops, rather harshly. This happens whether the windows are open or closed.
When I I had the car towed to the dealer to get the water pump replaced, the door latches seems smooth and flawless when I picked it up a few days later. I assumed the dealer noticed the harsh-feeling door latches and adjusted something. But a few days later both doors went back to their old ways.
Is there some sort of adjustment on the latches? The doors seem to line up properly, so it doesn't seem to be an issue at the hinges.
Old Jul 25, 2019 | 05:46 PM
This isn't good. After typing that I went out to the garage and sprayed the latch with some silicone lubricant. Now it feels even worse.
Old Jul 26, 2019 | 08:42 AM
shemp's Avatar
Mine does the same thing. Some days it is smooth as silk, other days I have to give a small tug like it's catching on something. I sprayed lithium grease into the latch mechanism (because it's accessible) but it did nothing as I expected. Someday I'll take off the door panel and get a look inside. Or you can and tell me what's wrong
Old Jul 26, 2019 | 09:33 AM
TexasTraveler's Avatar
GGG, had a great write up not to long ago about the replacement or rebuild of his door handle. Might be worth a read...
Old Jul 29, 2019 | 05:18 PM
sparky fuze's Avatar
Could be your Key Fob battery is weak or the fob is too far away when opening a locked door.
VancouverXJ6
Feb 10, 2018 03:31 AM
hisport
Jun 26, 2016 08:14 AM
steve_k_xk
May 12, 2016 04:42 AM
Corey.boyette
Oct 24, 2014 08:31 AM
Jagfix38
XJ40 ( XJ81 )
Nov 18, 2011 10:28 AM
