Door Panel Wiring Harness Replacement
Old Dec 4, 2025 | 10:09 PM
BLD's Avatar
BLD
Default Door Panel Wiring Harness Replacement
I am replacing the passengers side door panel (door card) wiring harness on my 2008 XKR convertible. I am having trouble disconnecting one of the connectors on the harness. The connector goes to the door latch handle (to operate the power door lock I suspect) . Attached are photos of the plug I am struggling with. I fear I may break the connector if I do it wrong or force it. Can anybody on the forum give me some guidance on disconnecting it? Is there a locking tab or something like that that needs to be depressed to release the connector?
Thanks for the help.
BD
Old Dec 4, 2025 | 10:23 PM
McJag222's Avatar
Does the white tab push back to release the plug?
Old Dec 6, 2025 | 12:53 PM
Sean W's Avatar
and is there one on the other side as well?
Old Dec 6, 2025 | 08:51 PM
BLD's Avatar
BLD
There is indeed one on the other side but the only way to get to it was to disconnect/remove the door handle from the door panel. The door handle is attached to the door panel by 5 small catch hooks on the panel. I was able to disconnect the plug by slipping small jewelers screw drivers under the white tabs as shown in the first photo below. Once I achieved all this I realized it was unnecessary. I could have just removed the door handle with the cable harness still attached. The reason for this whole exercise is my door panel on my car had a hole punched into when the door was closed with the seat belt buckle laying in the door jamb. I am replacing it with a salvage yard panel bought off of EBay.
Thanks for your help and suggestion.
BD
Old Dec 7, 2025 | 04:09 AM
Cee Jay's Avatar
..... and now we all know...
Old Dec 7, 2025 | 07:39 AM
kj07xk's Avatar
Pry this, push that, pinch here, twist that… just another connector from those sadistic connector designers. How many different connector types can one car have?
Old Dec 7, 2025 | 09:00 AM
guy's Avatar
guy
Or, thank goodness the connectors are actually locked in place so that they don’t wiggle loose at the most inopportune time… perspectives.
Old Dec 7, 2025 | 10:37 AM
kj07xk's Avatar
Agreed, but do we need 37,000 ways to hold a connection together?
Old Dec 7, 2025 | 11:10 AM
Sean W's Avatar
Yep. Find the engineer with the fattest finger and thumb in the building and then he, and only he, is allowed to design tool-less quick release connectors.
wjb
Aug 22, 2024 01:41 AM
Apr 2, 2024 05:32 PM
DlsXK
Mar 12, 2023 03:19 PM
Ronks2
Sep 3, 2021 09:07 PM
ZenFly
May 8, 2020 02:23 PM
