Door sill removal
I suspect it's a press-on friction fit that can be easily removed using a plastic trim tool to pry it up starting at a corner.
That's how I removed the sill plates on my XJ and replaced them with illuminated plates. It was easy because the XJ was pre-wired for the illuminated plates.
Thanks. I was not aware the the metal piece that has the Jaguar logo, is considered a decal. My drivers side has lifted slightly. I assume that it will be perished when removing it.
If you're only referring to the decal, mine started to lift and I helped it along with a putty knife, being careful not to pull up, bending it in the process. Then I re-glued or used silicone, don't recall I check it every time I wash the car. No problems.
thanks Sean. I am going to try this as well.
Thanks Guy. I think possibly using a fishing line, or dental floss, spread across the bottom, moving slowly until the decal releas3s.
