Driver door window going up and down when door opened - not a convertible
Old May 21, 2017 | 10:03 AM
ashburndave's Avatar
Default Driver door window going up and down when door opened - not a convertible
I just received a 2010 XK hardtop. It was shipped from another state so I hadn't had a chance to drive it yet.
Should the window go up and down a little bit when opening and closing the door? From what I've read that it's normal for the convertibles but I haven't seen anything about the hardtops.
Old May 21, 2017 | 10:09 AM
dsd's Avatar
dsd
Congrats on the car. I'm in Ashburn too.
You have an X150 and this is the X100 section.
That said, it wouldn't surprise me if the windows dip. Is there a frame around it? If not, I would expect the dip-- I have had several coupes do that.
Old May 21, 2017 | 11:03 AM
no frame around it so probably intentional then. sorry about the wrong section too.
Old May 21, 2017 | 11:40 AM
jimbov8's Avatar
Perfectly normal, open the door and it should drop slightly, close the door and should go back up.
Old May 21, 2017 | 06:55 PM
I've moved your thread to the X150 section
As this is your first post, please stop by the New Member Section and post an intro - in return, you will receive a warm welcome and some useful tips for forum navigation
https://www.jaguarforums.com/forum/n...-intro-must-5/
Enjoy the XK!!
Old May 21, 2017 | 07:38 PM
Ranchero50's Avatar
Ditto, check out Topix (google it) and download the manual if you haven't yet. Congrats on the car, post up some pics.
Old May 21, 2017 | 08:00 PM
ralphwg's Avatar
Welcome aboard, you are in for some fun. In addition you will find this forum to be filled with mostly very good,helpful people. Post some pics please.
Old May 22, 2017 | 02:51 PM
sov211's Avatar
In answer to the original question, YES the window mechanism is designed to lower the window to clear the weatherstripping into which the glass fits. When you close the door the glass rises again into the channel to seal against wind noise.
The first use of this sort of mechanism (I believe) was on the 1961 to 1969 Lincoln Continental convertibles - beautiful, and for their time beautifully engineered cars. The rear door glass dropped to clear when the rear door handle was used (and yes, these were 4 door convertibles with the front and rear doors opening at the centre.
justenough
Feb 7, 2018 01:42 PM
larueb
May 20, 2017 01:18 PM
WesleyFurr
May 13, 2017 04:53 AM
Katzenfieber
May 12, 2017 03:05 AM
philwarner
May 11, 2017 05:29 PM
