Driver seat won't come up
Old May 27, 2014 | 11:26 AM
carlprs's Avatar
Default Driver seat won't come up
My seat back will lower but won't raise. Has anybody had this happen. My battery is new and fully charged. I wonder if this is something I could repair? Any help greatly appreciated.
Old May 27, 2014 | 11:52 AM
WhiteXKR's Avatar
Try something simple first. Remove the fusebox cover in the driver footwell, and pull fuse F18 (tan , 5 Amps), then plug it back in. This should reset the driver seat control module.
Old May 27, 2014 | 02:15 PM
carlprs's Avatar
that would have been an easy fix but unfortunately it still won't raise. All the other functions work.
Old May 27, 2014 | 03:35 PM
WhiteXKR's Avatar
Then it is probably either the switch module or the seat module or a position sensor. The switch module and seat module are linked by a data bus, so it is not that easy to diagnose yourself.
Factory diagnostic equipment is the way to go at this point to avoid throwing parts at the problem unless you have really good electronic skills.
GordoCatCar
Jan 2, 2017 01:10 PM
Clamdigger
Sep 12, 2015 03:43 PM
wcourt3010
Sep 9, 2015 04:34 PM
joey g
US Northeast
Sep 7, 2015 06:28 PM
Dallas XK8
Sep 3, 2015 12:17 PM
