Duckbill and A/C Recharge
Back to the AC, if the system has some gas they can reclaim and use a vacuum pump to see if it holds a vacuum if it does then your system is good can be re-gassed accordingly, if not they can put a dye in the system and check with a UV light to see where its leaking and you can go from there. On mine it was leaking from front compressor O-ring they want over Ł700 for the part (not main dealer) I sourced the compressor new from 3rd party Ł360 and had an independent mechanic come and fit for less than Ł300. I regassed the system myself as I have vacuum pump and gauges could get enough gas the 134a online.
I just dont like people being ripped off so hope this helps
amcdonal86
Jun 8, 2011 02:56 PM
