Dynamic Mode Fault
Old Nov 28, 2024 | 03:52 AM
UltraBlackXKR-S's Avatar
Default Dynamic Mode Fault
I've finally gotten my hands on the XKR-S and everything seems in order besides one small issue: When I select dynamic mode in the center console, it gives me a warning on the gauge cluster "Dynamic Mode Fault" with an exclamation point. It ends up staying in the normal mode.
Looking around on the forums, I've seen people having issues with "Adaptive Dynamics Fault", but not this specific error. Any ideas?
Old Nov 28, 2024 | 04:32 AM
guy's Avatar
guy
Congratulations on the purchase!
We really need the codes…
Old Nov 28, 2024 | 07:02 AM
Thanks bro! I'll get back to you with that
Old Nov 28, 2024 | 03:03 PM
NBCat's Avatar
In addition to any stored DTCs, use a voltmeter to read the available battery voltage across the battery terminals with the ignition in the OFF position for at least 30 minutes. There should be a minimum of 12.6 volts showing on the voltmeter. If the reading is less than 12.6 volts, charge the battery at 2 to 5 amps for five hours and retest. If the voltage is still reading less than 12.6 volts, the battery is suspect and should be replaced. Many instrument cluster warnings, electrical 'gremlins', and random DTCs chased on these forums are the result of a failing or weak battery.
Old Dec 18, 2024 | 04:32 AM
Been slammed as of late, but I'm back and I've brought codes:U0415-00 and U043A-92
One is an undefined ABS fault, and the other is a suspension fault
Old Dec 30, 2024 | 11:31 AM
XKDreams's Avatar
The suspension fault would likely prevent going into dynamic mode, since tightening the suspension is part of dynamic mode. Try to reset the codes with an OBD2 scanner. Sometimes they can be cleared and not come back.
antoniofcano
Apr 8, 2024 11:16 AM
JJMcJay
Aug 31, 2022 02:25 AM
2013XK
Oct 17, 2018 08:35 AM
thelongwayhome
Apr 29, 2018 03:19 PM
ibo919
Oct 12, 2015 01:44 PM
