Earth point
Old Oct 14, 2024 | 11:43 AM
Madness's Avatar
Default Earth point
Good evening folks,
I am installing a power source in the front compartment for occasional use of a CarPlay unit. I am putting a piggy back fuse in the fusebox in the passenger compartment. Does anyone know if there is a convenient earth point near the fusebox? I will be running the wire back from the fusebox and round the front of the windscreen.
Many thanks in advance
Old Oct 14, 2024 | 11:52 AM
kj07xk's Avatar
If you’re talking about the fuse box in the front footwell, I used an existing stud with a nut on it. I had the trim around the fuse box removed at the time (to run wiring) so probably not accessible without removing the trim. The nut was toward the door, not toward the firewall. It was easy access at the time, but I’m sure there must be more than one ground spot around the fuse box.
Old Oct 14, 2024 | 12:15 PM
Madness's Avatar
Thanks for the reply. Sounds promising as I will need to remove some trim.
98Jagxjr
May 21, 2022 03:13 AM
jfranks
Sep 16, 2020 10:36 PM
SamtheSham
May 23, 2019 06:38 AM
VancouverXJ6
Jul 15, 2018 03:47 AM
dartech
Apr 6, 2016 08:31 AM
