Easy way to calculate HP? My MAF G/S is 382
Old Feb 12, 2017 | 09:37 PM
AlexJag's Avatar
Sponsor
Originally Posted by jahummer
Took it to the freeway and in manual mode let it shift on its own at 6500 rpm. Only reading MAF the highest number I got from 2-3 and 3-4 was 383 and times 1.1 that's 421. Did the tune and pulley not have any impact on the numbers then?
BTW I did modify both my stock intake boxes by cutting out the big plastic grill in front of air filters so Im wondering if my higher reading helps with this at all. I wish I would of done before the mod measurements. here is the link to what I did https://www.jaguarforums.com/forum/x...rboxes-165613/
Also my G/S measurement is with Eurocharged tune. Im going to turn it off and run it with stock file to see if there is a flow change.
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 112.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 SC (Alpha Jag ECU, TCU tune, crank pulley), 600+ HP, 11.6 sec 1/4th mi 122mph, 7.6sec 1/8th mi
2018 Jaguar F-Type (AlphaJag ECU TCU, lower upper pulleys intake) 10.77 ,131mph ,700hp
Old Feb 12, 2017 | 10:01 PM
AlexJag's Avatar
Sponsor
Originally Posted by Cambo
Maybe not, it depends on the tune.
There are a number of limiters in the PanPag PCM which could negate the peak HP effects of a pulley, if they aren't addressed then yeah, peak MAF numbers may not be higher than stock.
For example there is one limiter "Maximum load" which is an upper limit of the volume of air coming in to the engine, if this value is reached the PCM starts to close the throttle, that value needs to be raised in the tune or you will hit the ceiling, so to speak...
Crap I hope we are not fighting an uphill battle. If its true, any mods without this limiter removed are worthless.
I wonder if tuners address this at all
Maybe we can get Eurocharged and other tuners to chime in on this.
__________________
Old Feb 13, 2017 | 08:12 AM
avos's Avatar
Not sure where the limit is when the ECU steps in (probably not with just a upper pulley), but you can also see it in your recordings if the airflow suddenly drops to a ECU regulated flow. Or you can do another recording with just the throttle opening.
With the airflow value you only record a voltage from the MAF to which the ECU maps an then an estimated airflow, so the number will depend on the accuracy which as we know change over time. You can't measure any other improvements from tunes that alter the timing/fueling obviously. Last but not least, air density/temperature at the time of measurement plays a role as well, so without any corrections there, it will not be something you can use to compare with other cars (or your own runs!), its just a rough ballpark, and a cheap way to check if you have made improvements on the airflow only.
Old Feb 13, 2017 | 02:59 PM
AlexJag's Avatar
Sponsor
Wow Thats pretty darn impressive on how close Maf readings are to your actual whp numbers
383 g/s x .95 is 363 Dynojet WHP , and you got 361 whp on your dyno run
__________________
Old Feb 13, 2017 | 04:46 PM
Cambo's Avatar
What we really need is someone with a dead stock XKR to make the same tests and see what sort of numbers they get, I won't be in a position to do this for a while unfortunately...
Old Feb 13, 2017 | 04:59 PM
jahummer's Avatar
Indeed, hindsight is 20/20...
Old Feb 13, 2017 | 05:20 PM
Cambo's Avatar
My ex-JLR contact lifts this limit value in his tunes. You can ask others, see what they say, I think most don't/can't change this, maybe some can, I don't know everyones capabilities in detail.
Originally Posted by avos
Not sure where the limit is when the ECU steps in (probably not with just a upper pulley).
I don't know the exact number of the limit either but he says he reached it when developing his tune on his XKR... with a pulley, no cats & exhaust mods (x-pipe).
Old Feb 14, 2017 | 12:12 AM
  #28
avos's Avatar
The changes made in airflow he made are of course more then "just a upper pulley", but it shows that it is not far off.
My 1st experience with this limiter was on an early 2005 PanPag ECU for a RR where we had to lift this limit. This was for a TS at a higher airflow then just a pulley for the Eaton, but of course limits could be different with Jaguars software.
Old Feb 14, 2017 | 05:06 PM
AlexJag's Avatar
Sponsor
Default Comparing logs of Eurocharged, OE Tuning, Stock
I did runs tonight comparing Stock, Eurocharged tune and OE tune
somewhat confusing results.
I have logs for all of the experiments so if anyone wants to take a look let me know what can be understood.
Im not an expert but Eurocharged tune looks very similar to stock, where OE tune is very different and feel way more powerful in everyday driving
First was the Eurocharged tune, 388, 390, 383 g/s
Second stock 385, 379, 380
Third and last run was OE tune which runs crazy rich and was slower than stock on a 1/4mi but pulled 392, 388, 384
File Type: csv
File Type: csv
__________________
Old Feb 14, 2017 | 05:10 PM
  #30
Cambo's Avatar
Thanks for making the effort to do that.
Some head scratching required for sure here...
The only mechanical mod on your car is the 1.5 pulley yeah?
Old Feb 14, 2017 | 05:27 PM
  #31
AlexJag's Avatar
Sponsor
Pulley and the stock air filter box mod with the plastic grill being cut out and discarded.
__________________
Old Feb 15, 2017 | 05:30 AM
  #32
avos's Avatar
I did a check, but there are to much sensors selected to make a gr/s comparison obvioulsy, but you can see the Eurocharged tune is better because of the (big) timing advance, roughly 3 to 4 degrees more, and that could possible be about 25 rwhp or so.
One thing noticeable is that the engine load isn't 100%, so you may want to check if the ECU is holding it all back (so only select throttle opening). One thing to note, the ECU can also go into safe mode (similar action as with the torque limiter) if you hit the rev limiter hard, once done, it will only go back if you restart the engine.
Old Feb 15, 2017 | 11:33 AM
  #33
AlexJag's Avatar
Sponsor
Avos
thanks for checking the logs. Any idea why OE tune feels like it has a lot more torque down in lower rpm band?
Also you say eurocharged looks better with the timing increase but G/S show it only has 5+7 crank HP over stock which is a tiny gain not worth the tune Id say
Old Feb 16, 2017 | 12:17 AM
  #34
avos's Avatar
What would you define as midrange? I only looked at max power from 5000rpm, and then I don't know what to trust in figures (ie is the value for the a/f ratio correct?) etc.
Normally after a tune change I would make sure to drive a while 1st to see all settling down, to be sure there is nothing left in memory that could affect the readings. But I have no direct experience with the PanPag unit you have, as I see the fuel trims (memory) remains the same at wot over the 3 runs.
Please note that with your current logs you can't use the MAF gr/sec for mentioned reasons, so there isn't much I can get out of that. Next to that there can always be a small variance.
Old Feb 16, 2017 | 12:44 AM
  #35
steve_k_xk's Avatar
Are we able to see how much hp/air flow is robbed when the aircon is running
Old Feb 16, 2017 | 01:48 AM
  #36
JagV8's Avatar
Usually WOT cuts out the a/c.
Old Feb 16, 2017 | 02:28 AM
  #37
AlexJag's Avatar
Sponsor
  • ​​​​​afr ratios should be correct but they max out at 12.17 , so do not show any richer than that. Up to 3500rpms OE tune feels like it has 50 extra lb of torque compared to stock and eurocharged tune, I can see it goes rich with this tune as soon as a push the throttle slightly.Not sure the extra torque has to do with it being rich or maybe there is something else in OE tune that's giving it the extra power. Why can't we use the g/s again? It seems acurate and logs happen more than a few time/second
Old Feb 16, 2017 | 02:51 AM
  #38
Cambo's Avatar
As I already explained in the other thread, as soon as you go full throttle past a certain load the WOT Enrichment mode in the ECU kicks in and the O2 sensors are turned off. There is a commanded AFR but the actual AFR is not monitored by the PCM, and only the last value measured before the switchoff is broadcast via OBD2, which just happens to be 12.7
But the timing in the log doesn't exactly match up because there are so many measurements being recorded some are lagging behind.
Like for example, in your logs of the stock tune, timestamps 49:52.7 to 49:53.4, you've gone full throttle but there are identical numbers for the MAF, Fuel Trim %, etc, but some others are changing. This is a massive lag, in reality every split second these values are changing, but you cannot capture it. And then from 49:53.4 to 49:53.5 the MAF rate jumps from 97.91 to 266, that's not how it happens.
In the meatime during that period the PCM has switch to WOT enrichment, the O2 sensors are "off" and it's not until 49:53.8 that the logger has caught up on that measurment and is displaying the last number the PCM got before it switched off the O2's. It's about a full second behind the numbers recorded for the engine load. The MAF data is also "running late" as is the RPM's...
Old Feb 25, 2017 | 02:35 PM
  #39
JagSTR2004's Avatar
This is an interesting thread, I tried this to supplement my power runs. In third gear I saw peak readings of 441g/s which equates to approximately 485bhp or just over 400 to the wheels. This makes me pretty sure that when I had the smaller pulley on a week ago, I would've been over 500HP at the engine
Let's see if I can get back over it with some more mods.
Old Feb 25, 2017 | 04:42 PM
  #40
AlexJag's Avatar
Sponsor
Thats a impressive number if thats not a 5.0 engine
what mods do you have?
__________________
