Engine coolant temperature reading
Old Dec 2, 2020 | 01:38 AM
  #41
Barry Leftwich's Avatar
Originally Posted by Stuart S
Did you try to re-glue the window to the canvas? It's an easy DIY fix for under $100. Read my posts in this thread starting with #105 about using Rhino Glue and Suck 'N Clamps:
https://www.jaguarforums.com/forum/x...ble-top-97478/
I got this fixed a while ago now with a new top put on it and everything and i apologize for not leaving an update.But here's the new look I gave it
The New look of my Jag😎
Old Dec 2, 2020 | 09:18 AM
  #42
mhminnich's Avatar
I like it! Red over black has always been a favorite combination for me.
Old Dec 2, 2020 | 10:23 AM
  #43
Cee Jay's Avatar
Could also search the Googs, dozens show up.
Old Dec 4, 2020 | 10:56 AM
  #44
trkyam's Avatar
I use a $25 heads up display that plugs into your OBD2 and side on the left corner of the dash
displays speedo/tach temperature and voltage
Old Dec 4, 2020 | 11:35 AM
  #45
Arminius's Avatar
Please post a picture!
Thanks!
Old Dec 5, 2020 | 02:13 AM
  #46
Sovejag13190's Avatar
Hi HERE there is this model
Old Dec 5, 2020 | 08:31 AM
  #47
Arminius's Avatar
Originally Posted by Sovejag13190
GREAT Idea!
Found the same under another name on amazon:
Auto HUD Head up Display Intelligente Digitale Tachometer LCD Display OBD 2 Scanner Auto HUD Head up Display Intelligente Digitale Tachometer LCD Display OBD 2 Scanner
THANKS, Hermann
Old Dec 5, 2020 | 12:54 PM
  #48
MarkyUK's Avatar
And of course there's this ADU, othwrs will argud but I believe it looks OEM and cost me less fhan £100/125 USD
Sadly not available any more as a complete/built unit but you can order the componemts from the inventor
Old Dec 16, 2020 | 03:50 PM
  #49
Jomiltom's Avatar
Originally Posted by peterv8
or something like this?
Bought it from Aliexpress, search for HUD(heads up display)
In which hose did you connect the sensor?
I've been looking at my xk to put one like yours but I don't know where to install the sensor.
Old Dec 16, 2020 | 04:06 PM
  #50
trkyam's Avatar
Old Dec 16, 2020 | 04:19 PM
  #51
peterv8's Avatar
It connects to the OBD port, so very easy install.
Old Dec 16, 2020 | 10:59 PM
  #52
DGL's Avatar
DGL
Deleted. Found what I was looking for.
Old Dec 22, 2020 | 05:18 PM
  #53
Jomiltom's Avatar
What is the ideal temperature of continuous work that it has to give us with a connected obd2?
Old Dec 22, 2020 | 11:59 PM
  #54
peterv8's Avatar
93-95 degrees celcius
Old Dec 23, 2020 | 02:26 AM
  #55
Jomiltom's Avatar
Thank you.
This week they will bring me an obd2 similar to yours.
From what temperature is it considered excessive?
I think I remember that with a car diagnosis equipment stopped and the engine running, the temperature reached 97 ° C.
I don't know if I have a problem.
Old Dec 23, 2020 | 03:13 AM
  #56
peterv8's Avatar
Thank you.
No problem, I think if it goes over 100°c when in motion you have a problem.
Old Dec 23, 2020 | 09:03 AM
  #57
Jomiltom's Avatar
thankyou
Old Dec 24, 2020 | 12:55 AM
  #58
ralphwg's Avatar
Temp range in my XKR in Fahrenheit is between 193-210 depending upon traffic and speed.
Old Dec 30, 2020 | 08:03 PM
  #59
JackJohn's Avatar
The temperature range I see on my "07 is 193 -- 199f when in motion, sitting at a signal light it will rise to 204 -- 206f. Last Sunday on the way home from Florida, I got caught in a mile long traffic jam in Baton Rouge, temp got as high as 214f at this point I put the transmission in neutral and raised the RPMs to 2500, this brought it back down to 208f. I never got over temp warnings and as soon as I got moving again, the temp dropped back to 197f.
Old Dec 31, 2020 | 06:11 AM
  #60
Stuart S's Avatar
FIRST AID FOR OVERHEATING
If your car overheats and you're not in a place where you can safely stop and let it cool down, turn your heater on to maximum and run it full blast. Your heater is simply another radiator, albeit smaller, that circulates the engine coolant. Running the heater will help bring down the coolant temperature, assuming that you haven't lost all the coolant and that the water pump still works.
I shouldn't have to say this, but open the windows so you don't get roasted.
That's
