Engine Cover
I've moved your question from Jaguar Forums Feedback & Suggestion Center to X150 forum. The Feedback & Suggestion Center forum is for questions about the forum and not for tech questions.
Members here with the same model will be able to help.
It just pulls straight up. There are four metal posts, the plastic cover has 4 rubber grommets on the underside that hold it pretty tight on the posts. When I took mine off one of the rubber grommets stayed on the post, so I had to reinsert it into the holder on the underside of the cover.
To put back on you have to line it up on the engine then give it a solid pop to re-seat it back on the posts.
Tampamark, thanks for the quick reply. I am planning on having all three covers coated by Hydro Design to look like graphite fiber. I might have too much free time on my hands.
Make sure when you put the two small corner covers back on you don't have the plastic compression fasteners inserted. I left mine in. While lining that one up the fastener popped off and fell in the engine. It was a bear to retrieve. Better to line the holes up and then punch in the fasteners.
FS[Western US]: FREE- 99 XJR ECM and TCM
XJsc-guy
Sep 25, 2015 11:09 AM
KarimPA
Sep 12, 2015 08:15 AM
KarimPA
Sep 3, 2015 07:32 PM
