Engine Cover
Old Sep 16, 2015 | 03:50 PM
Gom's Avatar
Gom
Default Engine Cover
I am having trouble removing the center engine cover on a 2011 XK Coupe. I did not want to break some tabs Help!
Old Sep 16, 2015 | 03:58 PM
I've moved your question from Jaguar Forums Feedback & Suggestion Center to X150 forum. The Feedback & Suggestion Center forum is for questions about the forum and not for tech questions.
Members here with the same model will be able to help.
Old Sep 16, 2015 | 06:21 PM
tampamark's Avatar
It just pulls straight up. There are four metal posts, the plastic cover has 4 rubber grommets on the underside that hold it pretty tight on the posts. When I took mine off one of the rubber grommets stayed on the post, so I had to reinsert it into the holder on the underside of the cover.
To put back on you have to line it up on the engine then give it a solid pop to re-seat it back on the posts.
Old Sep 17, 2015 | 05:49 AM
Gom's Avatar
Gom
Default Engine Over -thank youth
Tampamark, thanks for the quick reply. I am planning on having all three covers coated by Hydro Design to look like graphite fiber. I might have too much free time on my hands.
Old Sep 17, 2015 | 07:39 AM
tampamark's Avatar
Time and money, a dangerous combination. Should look real nice.
Make sure when you put the two small corner covers back on you don't have the plastic compression fasteners inserted. I left mine in. While lining that one up the fastener popped off and fell in the engine. It was a bear to retrieve. Better to line the holes up and then punch in the fasteners.
Forcedair1
Sep 8, 2025 01:57 PM
dsnyder586
Dec 29, 2024 07:39 PM
XJsc-guy
Sep 25, 2015 11:09 AM
KarimPA
Sep 12, 2015 08:15 AM
KarimPA
Sep 3, 2015 07:32 PM
