Error Codes, Won't start
Old Feb 20, 2025 | 10:57 AM
Rastasal67's Avatar
No break in but it was left with the positive battery terminal disconnected during the repairs to save the battery.
If I remove the fuse that governs the steering lock will that release it or does it need to be reset in some way.
Old Feb 20, 2025 | 11:28 AM
sony2000's Avatar
Resetting steering lock? A lay mans answer is to use the key fob to lock the car twice. Do this a few times. Then get in and put the fob in its cradle. Now start the car.
Old Feb 20, 2025 | 01:53 PM
Rastasal67's Avatar
Ah, I was expecting something complicated having to unlock it manually or resetting it in some complicated way.
I shall give that a go thanks
Old Feb 20, 2025 | 04:30 PM
sony2000's Avatar
From the readings, another 150 experienced a locked steering from a small accident. In his case the rear view mirror had been disconnected which the CAN did not like, and locked the steering.
Old Feb 21, 2025 | 04:32 AM
Rastasal67's Avatar
I would have never considered that could have been the cause of the problem. I'll check mine to ensure its fitted properly thanks
Olonokis
Sep 29, 2024 05:36 AM
gally
Feb 28, 2023 08:19 AM
ArnoldKay
Jul 2, 2017 12:35 PM
Andrés
E type ( XK-E )
Dec 31, 2014 05:25 PM
Staatsof
22
Aug 6, 2010 09:48 AM
