Evan “not ready”
Old Jun 14, 2024 | 02:51 PM
poulson4's Avatar
Default Evan “not ready”
Went to have my 2007 XK annual car inspection done but failed due to “electric parking brake” not functioning.
Followed online reset steps that included disconnecting/ reconnecting the battery. EPB reset and was now functioning. After driving about 100 miles since reset, I went back to have reinspected but car now failed inspection due to “evap” and “2 sys” not ready (not reset since battery disconnect?).
Checked gas cap and drove car per various reset procedures but no change. Have not had any issues with battery which is less than 2 years old.
Any and all comments/ suggestions appreciated.
Old Jun 14, 2024 | 03:25 PM
guy's Avatar
guy
The common cause of an EPB failure, is an insufficient battery. The service manual dictates that a battery reading 12.5v may need charging or replacement.
As the appropriate vehicle codes are not provided, I can only assume that the learned emissions statistics are insufficient to pass your test.
(ie, you need to drive the car for a week)
Old Jun 14, 2024 | 03:55 PM
jahummer's Avatar
What @guy said
Old Jun 14, 2024 | 04:43 PM
guy's Avatar
guy
Beat you to it @jahummer ;-)
Old Jun 15, 2024 | 09:51 PM
poulson4's Avatar
Thanks for the feedback. My next step will be to check the battery voltage. Also would low voltage have been the possible cause for the original issue of the electric parking brake error?
Old Jun 15, 2024 | 10:19 PM
guy's Avatar
guy
in a word.. yes.
Old Jun 15, 2024 | 11:02 PM
mizzleman's Avatar
"that the learned emissions statistics are insufficient to pass your test" ......Had the same "evap" systems not ready when doing an annual inspection on several vehicles and it was due to a battery disconnect, not the battery itself. It can take up to 100 miles or so for the EVAP monitors to reset themselves. I fixed the issue by driving the vehicles around for a while. Then they were all set and passed the test. An OBDII reader can usually tell if the EVAP systems are ready or not ready before you go back for the inspection. Good luck.
Old Jun 16, 2024 | 11:08 AM
jahummer's Avatar
Correct and that's what guy was saying as well.
Baxter3319
Jul 10, 2021 10:09 AM
Steve-in-ct
May 15, 2017 12:33 PM
amitabhadatta
Jul 5, 2013 08:16 AM
avioni
Jun 7, 2013 10:22 AM
pdog2000
Feb 1, 2012 10:39 AM
