F Type Seats
Old Nov 15, 2020 | 10:46 PM
ThreadLock's Avatar
Default F Type Seats
Simple question to a possible nightmare but...Will they fit?
Old Nov 16, 2020 | 01:54 AM
tmich's Avatar
Not a direct answer to your question, but bear in mind that seats may have different features (heating, cooling, 100-ways of adjustments etc). It may not be a swap of a seat itself only, but also other electronics (incl. coding in SDD).
Ps. Even if mounting holes does not fit 1:1 for sure you can do some changes in them... But look above
Old Nov 16, 2020 | 08:05 AM
Mufc's Avatar
Get some from an XKR-S They will fit
Old Nov 16, 2020 | 09:49 PM
steve_k_xk's Avatar
Hello Threadlock
F type seats do not have tilt function for rear passengers to enter / exit
I’m gathering you want to put the performance seats in your xkr
xkrs seats in
2010 and upwards should be a straight bolt in plug and play / recalibration in SDD
2007-2009 (4.2) - wiring harness requires modification and seat modules from 4.2 into 5.0 seats would need to be swapped - Cambo is currently working on a harness adaption plug for me at the moment to make it all work
At time of purchasing my seats Cotswold automotive also had a xkr-s black/red stitch also available
Old Nov 17, 2020 | 01:46 AM
MarkyUK's Avatar
Mine, not ventilated though, so ideal for cooler climates
Old Nov 20, 2020 | 05:23 PM
jahummer's Avatar
Hello Threadlock
xkrs seats in
Steve,
Have you had a chance to weigh the original 16-way seats?
Old Nov 21, 2020 | 12:02 AM
steve_k_xk's Avatar
The performance seats are still at cambo whilst he's preparing the harness extensions so yet to weigh however they do feel like they are 10-15lbs heavier then the standard 47lbs xk seats bare with me I'll definitely weigh them and get a exactly figure when I go over next to see him next (I also have a larger rear boot lid spoiler there as well 😁&#128513
Old Nov 24, 2020 | 05:59 PM
jahummer's Avatar
Weighed up the 16-way passenger seat and it came in at 78 pounds which seems more like what I recall from 6 years ago when I had them out. Definitely heavy to carry compared to a 50 pound tyre/wheel.
Old Nov 24, 2020 | 06:13 PM
steve_k_xk's Avatar
CORRECTION - I’ve was a few pounds off the mark the xk seat actually weighs in at 60LBS (not 47lb as previously mention)
Nevertheless it’s a decent little saving of 36lb or so over the xkr seats
Old May 16, 2021 | 08:56 AM
jahummer's Avatar
Steve, Can you confirm the seat mounting points for the X152 and X150 are the same?
Old May 16, 2021 | 07:07 PM
steve_k_xk's Avatar
You'll need to swap around the mounting brackets so hold onto the ones from your xkr
Old May 16, 2021 | 07:38 PM
jahummer's Avatar
Right, so they're not the same then? Asking because I was going to post up in the F-Type forum regarding seat bases for race seats. So if the X152 mounts aren't the same as the X150, there wouldn't be any point then...
Old May 16, 2021 | 09:52 PM
steve_k_xk's Avatar
The rails are the same it's just the mounts that would need to swapped over which are two torx bolts per corner
So they would work one would just to retain their own mounts that are specific to x152 and x150
mecheng1
Nov 9, 2020 01:37 AM
CD2005
Aug 23, 2017 09:50 AM
rgabbert
Mark V - X 420G
Sep 5, 2016 06:45 PM
Stephenk
Jan 11, 2016 04:50 PM
