Front End Clunk (not resolved in forums)
Old Oct 13, 2020 | 11:37 AM
Chris N's Avatar
Default Front End Clunk (not resolved in forums)
Hi guys,
So far I've changed all the control arms, upper and lower and the sway bar end links. I've had it at two shops and no one can seem to find where the clunk on both sides is coming from. I've read all the posts in the forums and different solutions appear but none have resolved my issue. And the struts are fine according to both shops 69,000 MI. Can anyone tell me about this 2008 XK.
Old Oct 13, 2020 | 12:24 PM
Cee Jay's Avatar
Did you check the control arm mounting bushings?
Also, someone somewhere found a loose brake caliper making his clunk.
Old Oct 13, 2020 | 12:28 PM
Chris N's Avatar
I changed the entire part, bushings and all for all six control arms. The clunk is on both sides. I had a loose caliper clunk on my AllRoad before, but it was only on one side.
Old Oct 13, 2020 | 03:08 PM
guy's Avatar
guy
My “clunk” was due to a broken suspension spring and worn isolator. What interested me was the fact that the spring broke in a location where ride height was not affected.
of course, I have no idea of your particular situation as I’m not there to investigate.
Old Oct 31, 2020 | 01:24 PM
Outrun's Avatar
A loose subframe attaching bolt could cause this noise too.
Old Oct 31, 2020 | 07:19 PM
steve_k_xk's Avatar
Finally got to the bottom of the clunk I had been searching for in the front end it very much sounded like a stabilizer link rod however it was the bumpstop in the shock (upper metal mount had separated )
The upper mount had separated
Old Jul 11, 2022 | 03:56 PM
miles61's Avatar
Hello,
I know this is a couple years old now, but I also have a phantom clunk, that happens when turning over uneven surfaces, like turn into a sloped driveway or entry way, was this when you noticed the noise mostly? I get it also under extreme sharp cornering at speeds over what would be considered normal by some.
Thanks in advance
Old Jul 11, 2022 | 04:11 PM
wymjym's Avatar
the sway bar is under load in those situations...maybe a sb bushing is going away?
wj
Originally Posted by miles61
Hello,
Thanks in advance
Old Jul 11, 2022 | 05:20 PM
Cee Jay's Avatar
Hello,
Thanks in advance
Gotta get it on a body lift, then take a big ole pry bar to every joint.
Old Jul 11, 2022 | 06:54 PM
Sean W's Avatar
wj
Possible and this one is easy enough to eliminate. Disconnect the sway bar at the links and zip tie the links out of the way of the suspension. Drive around a few blocks to replicate the current noise. If the noise is gone, SB bushes and or links are the problem. If the noise is still there, look elsewhere. No need to drive fast and crazy to test this and this is useful if one doesn't have a lift.
If it's me, I would do what CeeJay suggests as it's the fastest way to identify the problem.
Old Jul 12, 2022 | 07:24 AM
miles61's Avatar
Thanks for the replies, I wish I had access to a lift, I think I'll try unhooking the sway bar and checking , I can at least rule that out. Also I was looking around for front struts and see they are very hard to find.
Again Thanks.
Old Jul 12, 2022 | 08:49 AM
Cee Jay's Avatar
Many shops will gladly give you a 'free' inspection, on the hopes that you will allow them to do any necessary work which is needed.
Old Sep 28, 2022 | 11:14 AM
BagelConsultant's Avatar
Hello,
Thanks in advance
This is one of the noises I get in my car turning into my driveway. It's super low speed but sharp right turn with a somewhat steep angle (Yay Brooklyn!). Gonna worry about it more next spring as the car is going in to winter storage in about a month.
Richard from Fraser Valley
Nov 30, 2023 02:59 AM
exiledbrit
Jul 16, 2022 11:53 AM
Spikepaga
May 2, 2015 07:52 AM
linconlsv8
Mar 13, 2015 06:05 AM
ez53436
Jul 10, 2013 10:19 PM
