Front end hot to the touch...
Old May 17, 2012 | 12:12 PM
TFlan's Avatar
Default Front end hot to the touch...
Recently I brushed against the right front fender near the headlight and noticed that it was still very hot 3 hours after the engine was shut off. Checked the other side and same thing. Opened the hood and put my hand on the top of the engine...couldn't keep it there for more than 2 seconds because of the heat. This was at night and the car was in the garage.
Took it to the dealer and was told this is normal as "you can fry an egg on the engine." I'm a bit leery about that.
Has anyone else noticed this and am I overreacting?
Thanks.
Old May 17, 2012 | 02:03 PM
Fraser Mitchell's Avatar
Well, you probably can't fry an egg, but you can certainly boil one !
I think what you have found is normal, especially if its very warm where you are. Engines are a big lump, so take some time to cool off.
Is everything else behaving normally ?
Old May 17, 2012 | 02:11 PM
Mikey's Avatar
Originally Posted by TFlan
am I overreacting?
I think so. If the engine is at it's normal temp while operating how long it takes to cool is irrelevant.
Old May 17, 2012 | 02:22 PM
mosesbotbol's Avatar
Does the fan kick on when you are driving?
Old May 17, 2012 | 04:22 PM
amcdonal86's Avatar
If it's in the garage with the door closed, it's going to take longer to cool down as there is no airflow around the car.
Old May 18, 2012 | 08:50 AM
TFlan's Avatar
Thanks to all for the feedback. I feel a bit better that all appears to be normal.
Regards,
H20boy
Dec 24, 2024 03:23 PM
bamforp
Aug 14, 2024 05:36 PM
RaceDiagnostics
Sep 7, 2015 07:28 AM
XKR-NC
Sep 4, 2015 08:23 AM
obwoodie
Sep 3, 2015 07:45 PM
