Front tire ware
Old Jan 22, 2021 | 11:12 AM
juan gram's Avatar
Default Front tire ware
can someone please help in identifying the problem with tire wear on the driver's side front, the passenger side front is ok , see photos.2013 xk base has 51,000 miles at this time
Is the cause a bent rim, bad bushings etc. ? I have had the alignment checked
Old Jan 22, 2021 | 11:35 AM
neilr's Avatar
What sort of alignment was done and what were the results of the alignment?
That wear pattern initially suggests that the rear alignment is wrong pushing the car one way and you steering against it to counteract. Is the inner edge of the passenger side tyre also somewhat more worn/rounded off?
Old Jan 22, 2021 | 11:48 AM
jagtoes's Avatar
It could be either a bent rim or an alignment problem where the toe may have been altered due to hitting a pot hole. I would go to someone who knows how to do a 4 wheel alignment and ask for a read out of the alignment which should compare spec. to final alignment. Also have the rim checked for run out when they are going to mount a new tire.
Old Jan 22, 2021 | 12:10 PM
juan gram's Avatar
Thanks for the input, The passenger front tire is fine (see other photo), I had an alignment done by the local tire shop, they said everything checked out ok ???
Old Jan 22, 2021 | 12:29 PM
jons's Avatar
both of these photos are taken from standing in front of the tire, at different tire rotation positions? and it's just that one visible length of the circumference of the tire that's damaged? that's scalloped, or cupping, there's probably suspension damage or maybe some kind of periodic vibration from something loose. a toe/camber issue alone would wear evenly around the entire circumference of the tire.
Old Jan 22, 2021 | 12:30 PM
jons's Avatar
ah, nevermind, you're saying the second photo is of a perfectly good tire.
Old Jan 22, 2021 | 01:49 PM
juan gram's Avatar
Yes the other photo is the passenger front which looks fine, so only the driver side front is the problem, sorry for the confusion
Old Jan 22, 2021 | 01:52 PM
juan gram's Avatar
Before i go to anoher shop , i would like to know what the fix might be , thats why i am looking for help here
Old Jan 22, 2021 | 02:47 PM
juan gram's Avatar
I have the 20inch wheels, how do I check for a bent rim
Old Jan 22, 2021 | 02:58 PM
jagtoes's Avatar
You check the rim by rotating te tire and using a dial indicator against the wheel lip to see the run out. You should take the wheel off of the car and look at it to see if there is any visual tire or wheel damage. A tire shop can tell you this. Because of the wear you know something is wrong so it could be a few things like wheel damage , suspension damage or axel damage. We can point to any of these causes but you need someone who can look at the problem. Otherwise we are all guessing here.
Old Jan 22, 2021 | 03:05 PM
guy's Avatar
guy
Both tires look very worn to me. And it doesn’t seem a proper 4 wheel alignment was done as that should expose a worn suspension issue.
If the wheel is bent, that should expose itself very quickly on a wheel balancing.
Old Jan 22, 2021 | 03:10 PM
steve_k_xk's Avatar
Get the wheel shop to email through their report , then we can all can collectively take a look at the results .
I'm currently on f type gyrodynes solely due to fact of a heavy car/low profile tyres and 4 buckled senta wheels so yes very likely you could have a damage rim as well
Old Jan 22, 2021 | 03:47 PM
juan gram's Avatar
Default Tire wear
Thanks for all the information, you all make this a great site
Old Jan 22, 2021 | 08:34 PM
jagtoes's Avatar
When I had my alignment done here is what the data sheet looked like from the aligner. 1012 XKR conv.
File Type: pdf
Old Jan 22, 2021 | 09:06 PM
steve_k_xk's Avatar
interesting jagtoes the right front caster is just within specs
Old Jan 22, 2021 | 09:13 PM
Sean W's Avatar
looks like camber wear to me. Check struts, tie rod ends, ball joints, control arm bushings. Less likely, check the front wheel bearing.
Old Jan 23, 2021 | 07:17 AM
jagtoes's Avatar
At the time I was not to pleased but as you know the caster adjustment is more time consuming so being within spec was OK. Buy the way this is the 2nd time I had them do the alignment as there were other parameters that were to close to the max. I looked at his 1st data sheet and had to escalate to the service manager to have him redo it. Funny thing was most of the adjustment lined up with the orign. factory marks. The 1st 2 pics are before and the 2nd 2 are after.
Old Jan 23, 2021 | 04:02 PM
juan gram's Avatar
I know this is off the subject, but I notice your vehicle is the same color as mine. I have a 2013 xk white with white seats. Tried to contact Jaguar to find out how many were made in 2013. Got a reply from the accessory shop directing me someplace else. Have you made any inquires about your car?
carzaddict
General Tech Help
Mar 24, 2020 08:35 PM
ek993
Mar 23, 2016 11:02 AM
top140
May 29, 2013 03:08 PM
Vee
Nov 19, 2012 02:47 AM
ilovetrains
Feb 11, 2009 07:50 PM
