Fuel pressure sensor
Old Jun 26, 2023 | 01:15 PM
unklebuck's Avatar
Default Fuel pressure sensor
I had a code come up tonight on the way home P0193 fuel rail pressure sensor A circuit high. I couldn't find a definitive process here on how to change.
Can I just remove and replace or is there a procedure prior ie: remove fuel pump fuse, start car until dies. diconnect battery etc etc.
I dont think this has ever been replaced, nothing in the history.
The part thats there currently is a ford part see pictures.
Old Jun 26, 2023 | 02:21 PM
mhminnich's Avatar
Held in by 1 tiny bolt. Be careful not to drop it!!! Follow the workshop manual for depressurizing the fuel rail.
Old Jun 26, 2023 | 02:30 PM
unklebuck's Avatar
looking at the part there are two small bolts
Old Jun 26, 2023 | 03:11 PM
panthera999's Avatar
be careful of that crappy grey plastic vacuum pipe. It crumbles easily, and the connector can break off as well. Ask me how I know....but the good news, is that if you break it off, it glues back together reliably. Also, the shitty grey plastic line can be replaced by rubber vacuum line by shoving the last 1/2" of the grey plastic into the vacuum line at each end.
Old Jun 26, 2023 | 03:51 PM
unklebuck's Avatar
I think a warm up and a trim fork either side slid in might help remove it... hopefully!
dh53
Apr 5, 2022 01:15 PM
Vik976
Nov 6, 2019 07:59 AM
Cafcpete
Sep 2, 2019 04:20 AM
BradsJag
Nov 6, 2018 09:04 PM
EsRay
30
Nov 2, 2018 10:49 PM
