Garage door opener
Old Jan 5, 2022 | 09:33 AM
jag_man653's Avatar
Default Garage door opener
Just replaced my 26 year old LiftMaster garage door opener. The installer advised me that due to LiftMasters use of a different frequency band, my 2013 XK inbuilt opener button can't be programmed to control it.
Anyone else here dealt with this issue? Always on the lookout for the most complex solution to problems, I'm thinking there must be a "frequency band shifter."
Ed
2013 XK SE coupe
Old Jan 5, 2022 | 10:10 AM
Cee Jay's Avatar
There is such a thing. It's referenced several times in at least one thread in this forum and can be found using the SEARCH function.
The Google can also find many of these things.
Old Jan 5, 2022 | 11:04 AM
shemp's Avatar
My son has a 2014 XFRS. We were never able to get his liftmaster to work with it. Tried everything.
Old Jan 5, 2022 | 11:46 AM
jagtoes's Avatar
Go to the lift master web site and they have a signal accessory that will fix your problem. Here is what it looks like.
Old Jan 6, 2022 | 06:49 AM
tampamark's Avatar
Like mentioned, I bought this Homelink Repeater/Bridge Jagtoes has pictured several years back when I also updated my Garage Door opener and couldn't get my XK homelink to pair. This device works like a charm.
LiftMaster 855lm Homelink Repeater Kit - - Amazon.com LiftMaster 855lm Homelink Repeater Kit - - Amazon.com
Old Jan 6, 2022 | 09:08 AM
jag_man653's Avatar
Thanks, guys! The installer did say LiftMaster had an add-on device but didn't speak highly of it. Perhaps he was afraid I'd ask him to make it work
I'll get one and give it a try.
Ed
Old Jan 6, 2022 | 09:30 AM
lear60man's Avatar
Did you try this procedure yet? It has an extra couple of steps and was the only way to get all three of our JLR products to work.
Old Jan 6, 2022 | 04:56 PM
007XKR's Avatar
I ultimately found it easier and less aggravating to carry around the garage door remote than to program the X150 opener. I do have some extra add-on crap for liftmaster that I wish I hadn't purchased...
Old Dec 7, 2025 | 04:17 PM
selvanaidu's Avatar
I have a 2015 Jaguar XKR, and a newer LiftMaster 8500W Garage door opener. I had to buy a LiftMaster 855lM Homelink Repeater Kit, mentioned above by Jagtoes. I followed the instructions from the Jaguar owner's manual, and on 2015 cars, you have to have the ignition on, without starting the car. Use the remote transmitter that came with the repeater to program the car, and the Homelink module in my 2015 XKR gave me a fast flash. I then had to hit the "Learn" button on my garage door opener and press the Homelink button in my car. It took 3 tries and then the Homelink module synced with the garage door opener. Hope this helps other 2015 XK and XKR owners.
Old Dec 7, 2025 | 07:58 PM
Circumnavigator's Avatar
Anyone know if all of them are the same from 2007-2015?
I have 2 openers, one is the newer rotating code (Wife's side) and one is old school dip switches.
I've tried a dozen times, many different ways. Followed 2 diff video instructions (Older guy from Australia included) and zero luck.
Am I doomed to get a new opener or keep a clicker in my car?
I'll say I find it weird, since my old school was the type that was around when my 2008 was released.
Old Dec 21, 2025 | 04:55 PM
HealeyJag's Avatar
Live in a condo..so cant do much..gonna try again..but its ok to use the unit
wifes new Audi programmed great, she did it herself,,, her car...
drboz5750
Dec 27, 2020 10:18 AM
Brian XK8
Jul 6, 2016 06:36 AM
truckdogg4
Jan 8, 2007 10:39 PM
