Gear Oil replaced
Old Jun 10, 2016 | 08:59 PM
shamronbeach's Avatar
Default Gear Oil replaced
Replace rear end gear oil the other day. Really low and no leaks detected. Only purged about 16 oz. of old gear oil and installed 1.25 liters of Valvoline 75-140 limited slip. It was pretty easy. I used a hand purge to remove old oil and with a 3' piece of 3/8s tubing was able to refill from outside by the rear wheel. Worked great. I have done this several times onZ28 and GTO.
Old Jun 13, 2016 | 08:04 AM
flyc2c's Avatar
Curious why you didn't use Ford 75w-140? About the same price and spec'd for our cars. Didn't really need the limited slip type since the 07-09 has a craptastic open diff.
Old Jun 14, 2016 | 05:54 PM
guy's Avatar
guy
I luv that technical term!
Old Jun 14, 2016 | 05:56 PM
guy's Avatar
guy
Thats enough for me! No leaks and low is pretty sad. I've been wanting to get to that... But I will be using synthetic. Out of interest how many miles on your car?
Old Jun 14, 2016 | 08:29 PM
I missed about using the ford gear oil. The auto parts store looked up what type and it said GL5. I was not sure if it was limited slip and read somewhere it was ok to use limited slip. Seems to work fine and no problems.
Old Jun 14, 2016 | 08:32 PM
The Valvoline I used was full synthetic.
Turbotech
Feb 28, 2018 11:29 AM
Probesport
Jun 23, 2017 03:20 PM
Spikepaga
Sep 7, 2016 01:58 PM
gthawk1
Apr 6, 2016 01:25 AM
DanielSWE
Mar 28, 2016 06:22 AM
