Glove box door flopping open
Old Jun 17, 2016 | 02:34 PM
bocatrip's Avatar
Default Glove box door flopping open
My 2010 XK is having the glove box door issue causing it to drop open abruptly after releasing the open button rather than slowly as designed. I've read some threads about the glove box damper failing which is apparently very common with our cars.
I believe it requires removal of the glove box. I have an Easy Care Gold extended warranty 6 years/72,000 miles of which I have never used even once. It pretty much covers everything other than trim.I have a $50 deductable.Should this be covered under warranty or should I anticipate the dealer giving me any problems? Thanks all.
Old Jun 17, 2016 | 02:46 PM
jagtoes's Avatar
I have the same issue with my 2012. Last time I was at the dealer he said it would be covered under my original warranty and my CPO warranty. He said they need to replace the glove box and he had put one on order. So far it's been 2 months so being that you bring this up I'll have to check with him. You would need to see what coverage you have in your warranty contract because I believe this will be a pricey item.
Old Jun 17, 2016 | 03:10 PM
bocatrip's Avatar
Easy Care Gold is used by many Jaguar and Porsche dealers and is quite comprehensive. There is almost no exclusions other than trim, catalytic converter, and after market audio items, wheels, and modifications. Apparently the design for the opening is very flimsy for such an expensive car. All I read about were DIY fixes but nothing about warranty work.
Old Jun 17, 2016 | 03:14 PM
Stuart S's Avatar
bocatrip,
jagtoes experience is probably irrelevant to your situation because his car is covered by the original and CPO warranties that are from Jaguar, the manufacturer. Your "Easy Care Gold" coverage is not a warranty because, even though it was sold to you by your Jaguar dealer, it is not provided by the manufacturer. It is an extended service contract that is provided by a third party and is similar to an insurance policy. You should read your contract, particularly the exclusions and limitations. Don't let them weasel out of paying because of some vague and ambiguous provision. But if they do, it's a fairly easy DIY fix from what read on this Forum.
Stuart
Old Jun 17, 2016 | 03:28 PM
bocatrip's Avatar
Originally Posted by Stuart S
bocatrip,
Stuart
Thanks Stuart. I just got off the phone with my service writer and apparently there is some kind of TSB for this repair which does not require replacement of the glove box door. He told me it would be covered. I would only be responsible for my $50 deductable. I read the contract again as I did very thoroughly when I purchased it and there are virtually almost no exclusions other than what I mentioned above. Of course I'm always skeptical of all warranties especially with Jaguar. I have a friend currently having his XK's head gaskets replaced under a 3rd party warranty which I believe he purchased through Toyota. Of course, that's why I purchased it mainly for the big stuff.
Old Jun 17, 2016 | 03:39 PM
kj07xk's Avatar
Yes, fixing the problem is easy, its getting the glove box back in, such that everything lines up properly, is a PIA.
I've taken the glove box out twice, first to fix the floppy door, and a second time to install my ACM, and putting the box back in again wasn't any easier the second time.
If you can get it down under a warrantee, congrats, let them do the work.
Old Jun 17, 2016 | 04:18 PM
Sean W's Avatar
isn't there a little spring loaded device on the back of the glove box the prevents the door from flopping open?
I installed my ACM and saw the piece with a nylon string loop that leads out the end of it. I couldn't figure out where the loop attaches, so now I have the floppy glove box issue. Sadly, no warranty and no mention of this in the service manual that I can find.
Old Jun 17, 2016 | 05:37 PM
u102768's Avatar
TSB attached.
Old Jun 17, 2016 | 06:49 PM
kj07xk's Avatar
Originally Posted by u102768
TSB attached.
Yep, that's all there is to it, simple fix.
Old Jun 17, 2016 | 08:38 PM
bocatrip's Avatar
TSB attached.
Great work U10. Better that one of the Jaguar techs will be doing this than me. I'd definitely screw it up. It's the least they can do for my $3500 extended warranty! Thanks again
Old Jun 18, 2016 | 11:56 AM
tampamark's Avatar
Both of my XK's had this issue, the first one was repaired under factory warranty. After that car was totaled my replacement XK had the same issue, only this time I was looking for it and had it repaired before delivery.
Funny, on the first XK I noticed that the glove compartment was falling and bouncing so I pointed out that it looked strange to me, the sales guy that was turning the car over to me said that was normal. Despite being the first Jag I ever owned I found that hard to believe so I researched the forum and saw it was a common problem. Since I was under warranty it wasn't a big deal for me, I just had that and a couple of other issues handled before it expired.
Old Jun 18, 2016 | 12:29 PM
Cee Jay's Avatar
What is it, three screws to remove the box, two connectors and then fix the damper by drilling a small hole and reconnect the wire with a tiny screw. The $50 deductible would add up to about $300 per hour in labor.
Old Jun 18, 2016 | 01:35 PM
jagtoes's Avatar
Funny after seeing this post I sent a note to my dealer service contact and asked him what was going on with my glove box. He sent me a note back and told me the new glove box will be in in 14 days and we'll arrange to get it installed. I then sent him the TSB number and mentioned this was the fix so either they can do the fix or install a new glove box. Either way it is covered under the original warranty.
Old Jun 18, 2016 | 03:19 PM
tampamark's Avatar
Yep, my first XK fix the Tampa dealer ordered a new glove box as the warranty fix.
Crown in St Pete fixed with TSB repair. One was paid by Jag warranty, the other was out of warranty and a pre-delivery repair on their dime, maybe that is why they fixed instead...
Old Jun 18, 2016 | 10:48 PM
bocatrip's Avatar
More than likely, the TSB might be a more permanent fix as so many of glove boxes fail. I'm sure Jaguar never updated the replacement boxes as even the later model XKs experience the same failure.
Old Jun 18, 2016 | 11:52 PM
tampamark's Avatar
Maybe, but from what I can see in previous forum DIY pictures the plastic piece that the dampener wire connects on breaks. Just drilling another hole in the plastic and reattaching the wire just seems to be another broken plastic part later.
Old Jun 19, 2016 | 12:43 AM
tnt10's Avatar
Seems to me that the 0.3 hrs to fix, per the TSB above, makes this a reasonable dealer fix for the "less than handy" or "afraid to screw it up" amongst us!! (or am I missing something...??)
tnt10
Old Jun 19, 2016 | 07:24 AM
kj07xk's Avatar
It's a plastic peg in plastic frame that breaks. By using a metal peg (bolt or cotter key) placed in a thicker part of that frame, is a stronger solution, so I think the TSB style fix will last longer than the original.
Old Jun 19, 2016 | 07:40 AM
wrair's Avatar
I nervously attempted the fix myself (2010 XK), mainly because I don't trust the work of my local Jag dealer (came back for a couple of warranty fixes that included free finger print grease marks, scratches around the plastic underneath the wiper blade, in other words, any warranty work requires my post-cleanup!).
Anyhow, the TSB fix includes drilling a whole in a stronger part of the plastic, and I have not had a repeat failure (going on 2 years now).
And, more important, the fix was pretty easy. I don't have the link (sorry), but some kind person in this forum posted great pictures of each step and captions for the pictures that were easy to follow.
Try it. Very satisfying!
Old Jun 19, 2016 | 10:03 AM
tampamark's Avatar
Thanks guys, that clears it up! The TSB says to source the new cotter pin used for the repair locally, someone at Jaguar got smart and "re-engineered" the original design.
