Has anyone re-finished their interior wood trim
Old Mar 2, 2023 | 10:05 AM
Sean W's Avatar
Default Has anyone re-finished their interior wood trim
Like the title says. I've been able to locate part of the interior wood trim for my 07 in Piano Black. I have the passenger airbag trim, drivers side trim under the gauge and the center stack. They came off of a 2012 I think. At any rate, I've been searching for the center console and ash tray trim for years.
I bought a burl wood console off eBay and would like to tackle refinishing it.
I know I can wrap it and I may do that so thanks in advance for that suggestion.
I don't have body work skills and don't like refinishing furniture but am willing to take this on. I've done some finish work with a spray gun but it's been years and the last time I used a spray gun was to re-dye some leather seats. Turned out great btw.
OK so some questions please:
Removing the clear coat. Has anyone done it? Can it be stripped with something like paint stripper or is sanding the only option?
Primer - I assume a two part epoxy primer?
Paint - Gloss Black Epoxy paint applied with a gun?
Clear coat - UV poly clear coat?
I'm most interested in getting the original clear coat off and get to the would. My assumption is that I can't just break the glaze and start from there.
Thanks in advance
Old Mar 2, 2023 | 01:22 PM
sov211's Avatar
The wood is a very thin veneer on metal or plastic (depending on the location of the piece), so you are best to leave the existing finish in place - do not try to get down to the veneer itself. VERY gently sand the existing finish with a fine (perhaps 1000) grit wet/dry paper, and the apply the finish you want.
Old Mar 2, 2023 | 02:53 PM
mhminnich's Avatar
Don't strip it. Sand it smooth with 800 grit then apply your new finish. There is nothing to be gained by going further than that. As I was once taught, the best surface for a new paint job is a good old paint job
Old Mar 3, 2023 | 05:53 AM
guy's Avatar
guy
I agree on both accounts. Lightly sand to dull the finish. I’d use a high quality bristle brush myself. (experience with furniture, boats, etc)
Paint. Allow to dry.
Sand again,
Paint, Allow to dry.
Sand again,
paint.
There are a number of very good products to consider. Varethane (sp?) minwax, etc.
My experience is that Varethane is the most robust handling weather changes very well.
Old Mar 3, 2023 | 07:31 AM
wymjym's Avatar
I used to refinish MB interior wood. Used 2k clear as a finish coat...last year watched a fellow finish a guitar with high build clear, UV cure.
The UV cure took 4 minutes and no further shrinkage...if I were going to do it today, the UV cure material would be my choice.
WJ
Old Mar 4, 2023 | 08:06 AM
guy's Avatar
guy
Hadn’t heard of that. Thanks. Investigating.
Old Mar 4, 2023 | 09:19 AM
Sean W's Avatar
Whoops, I wrote epoxy above in my initial post. I meant enamel. Thanks for the help. This is now on my to do list.
olivermarks
Apr 22, 2026 10:00 PM
RA110623
Dec 10, 2021 06:48 AM
Peter Ucinski
May 4, 2020 02:07 PM
jazzwineman
22
May 17, 2016 08:14 AM
JagXV6
Interior
Oct 1, 2008 05:53 PM
