Headlight flickering
Old Aug 25, 2024 | 10:34 AM
Fred1996's Avatar
Default Headlight flickering
My high beams started flickering a couple of weeks ago and as of yesterday the same for the low beams. Both lights flash on and off intermittently.
This started when I was driving through a deluge and massive thunderstorm and fee weeks ago. Not sure if related.
I'm assuming this could be a relay going bad?
Maybe something else?
I'll have to get into the manual and see where the relay is located.
Any help greatly appreciated.
Old Aug 26, 2024 | 09:36 PM
Fred1996's Avatar
So going through the manual it would appear that perhaps there is a headlamp relay in the Central Junction Box in the passenger compartment (RH side, NAS spec??).
Can someone tell me if this is serviceable or not? I couldn't find anything that says specifically where in the CJB the relay is and if one can be purchased separately.
Thanks all.
Old Aug 28, 2024 | 09:24 AM
giandanielxk8's Avatar
My first suspect is the ballast. Your car has a Xenon headlamp, and the ballast converts the A/C current to DC current to be able to power up the HID bulb's igniter. Flickering headlights is the classic symptom of a failing ballast. This part is serviceable, and is usually found on the bottom side of the headlight.
Calab
XJ40 ( XJ81 )
Feb 25, 2023 08:25 AM
jomo
Jun 17, 2022 06:26 AM
adenshillito
May 17, 2017 09:05 AM
marvin1960
Apr 23, 2016 08:51 PM
dixie1351
Jun 17, 2009 01:16 PM
