Headlight help
Old Jun 15, 2019 | 09:30 AM
Ray T's Avatar
Default Headlight help
I have a 2007 Jaguar XK my front passenger headlight works fine and the directional bulb works also but the all the bulbs inside the headlight do not my daylight running bulb is not working and my directional cornering light is not working is there a separate fuse for this, when I opened up the headlight the wires inside all frayed in the metal was exposed, two wires with touching so I figured this had to short out somewhere along the line I haven't had any luck looking for a fuse that just handles these couple of Lights thanks
Old Jun 15, 2019 | 08:52 PM
Ranchero50's Avatar
You'll need to take the lens off and repair the wiring. The UV exposure from the lamp is hard on the wiring covering. Download the free service and wiring manuals to help figure out what fuses feed what circuits. Good luck with it.
Old Jun 16, 2019 | 04:59 PM
Jaginri's Avatar
Default Lens removal
Ok is there a trick to removing the lens from the headlight body
Old Jun 16, 2019 | 05:45 PM
Cee Jay's Avatar
Put it in the Oven! Seriously. Low setting for a couple hours.
Old Jun 16, 2019 | 06:01 PM
winstonsalemncxk's Avatar
235 for 20 minutes....
Old Aug 25, 2019 | 07:26 AM
TraxtarXKR's Avatar
Has anyone ever seen oxidation on the INSIDE of the lens? My headlights are a bit foggy, and it looks like I can see some bubbling on the inside of the lens.
Considering using a restoring kit on both sides of the lens, but I don't see many others having had to do this before.
Old Aug 25, 2019 | 09:42 AM
Sean W's Avatar
Give it a go on the outside first. Mine looked like some of it was on the inside but turns out it was all on the outside.
waltnich
May 2, 2019 09:40 PM
TomR166
Jan 5, 2019 02:26 PM
Beagle
Dec 4, 2015 02:27 PM
Anfield Dreaming
May 4, 2015 12:34 PM
jagosaurus
Oct 3, 2012 01:51 AM
