Heater Problems
Old Mar 2, 2016 | 11:21 AM
ggm31v's Avatar
Default Heater Problems
On my 2006 56 Reg XKR I'm having some issues with the climate control.
The vents in the centre of the dashboard above the navigation always blow the same temp despite what i set the digital climate too.
The other ones in the footwells etc do adjust accordingly though, which is confusing me. The suggests the climate control module is sending the signal out hence the others working.
Any suggestions?
Old Mar 2, 2016 | 02:35 PM
Ngarara's Avatar
Could be the blend motor that drives the flaps that control the mix of hot & cold air (there's two, one for left & one for right). You might get a fault code if you use a code reader.
phil66
Feb 22, 2017 05:01 PM
HectorM52
Jun 13, 2016 07:30 PM
tommac
Feb 17, 2016 06:00 PM
Davfrankl
Feb 17, 2016 10:46 AM
Mendo XK
Feb 10, 2016 10:37 PM
