HELP ... Cigaretta lighter color code?
Old Feb 18, 2018 | 11:19 AM
jlpatton's Avatar
Default HELP ... Cigaretta lighter color code?
Can anyone please tell me which wire to use to connect my ISIMPLE FM modulator? I have my car console apart. I have three wires going to the cigarette lighter and they are white/blue w.....a black wire and a smaller red/yellow wire.
PLEASE ONLY ANSWER IF YOU KNOW FOR SURE
I do not have a way to get a VOLT meter right now
Old Feb 18, 2018 | 11:57 AM
WhiteXKR's Avatar
Black is ground and white/blue is ignition switched power. Those are the ones you want.
The other wire is for the cigarette lighter illumination...do not use that.
Old Feb 18, 2018 | 12:01 PM
Ranchero50's Avatar
What year and flavor car? Not going to search your old posts to figure it out.
Might be simpler to download the free wiring diagram too.
My '07 diagram only shows two wires going to the front cigar lighter. White/Blue and Black.
Old Feb 18, 2018 | 12:05 PM
Stuart S's Avatar
Are you in the right forum? This is the 2007-up XK/XKR Forum. Your Personal Profile shows you have a 2001 S-Type.
Old Feb 18, 2018 | 12:31 PM
jlpatton's Avatar
THANKS!!! Yes I am in the correct forum.... I love this site and have only purchased Jaguars due to this site.....I have own nothing but Jags since about 8 years ago...I need to update my auto... I now have an 07 Jaguar XK named MASTRO... THANKS!!! I AM GOING WITH THE BLUE/WHITE as the positive and will try to wire the ground to the auto...THANKS I will be back later to update with results!!!! THANKS!!!!
Old Feb 19, 2018 | 11:10 AM
jlpatton's Avatar
THANKS EVERYONE!!!
And a very special Thank you to "White XKR.
everything is working smoothly...and no problems after installing.
My only complaint is that the sound quality was a bit less that what I expected, I had one of these installed in my X-TYPE and the sound quality was a lot better .
jazzwineman
Mar 8, 2017 09:05 AM
sg18438
Feb 22, 2017 09:35 PM
Corycarlo
Oct 19, 2015 05:32 PM
BrentGardner
May 22, 2014 03:01 PM
hankycbr
Oct 9, 2007 04:21 AM
