HELP! New Clunking, is this the Rear Differential?
Old Sep 13, 2016 | 12:20 PM
F15DOC's Avatar
Default HELP! New Clunking, is this the Rear Differential?
So yesterday on the way to clinic my 2007XK started clunking, at first I thought it was a rear tire, but no warning light for pressure. Pulled over, all looked good.
Resumed my way to work and the clunking continued.
Downhill (coasting - off accelerator) it is definitely worse.
Accelerating not so bad.
Turning sharply and decelerating is the definitely the worse.
Not changes with brakes on, not a brake wobble, definitely a clunking.
Repetitive in synchrony, speed related, not RPM related, gearing does not seem to matter much.
Had my wife do a drive by accelerating and decelerating, I could not hear it from outside the car.
Can definitely hear and feel it inside the car.
Diagnosis time, my suspicion is rear differential. I am a backyard mechanic and can do many things myself, so help me figure this out.
If it is the rear diff, I am not tackling that job and will definitly have a shop do the repair for me.
All advice is appreciated, for now, she is parked until I get an answer.
Old Sep 13, 2016 | 12:29 PM
Cee Jay's Avatar
Check it this way... with the brake on and engine running, shift from D to R, then back again several times. Could be the diff or the CVs on the prop shaft. Or even the rear half-shafts.
Old Sep 13, 2016 | 12:30 PM
F15DOC's Avatar
What am I looking for when I go from D to R?
Old Sep 13, 2016 | 12:33 PM
F15DOC's Avatar
I felt nothing unusual, no clunks, no sounds, just a normal shift.
Old Sep 13, 2016 | 01:41 PM
kj07xk's Avatar
Maybe a wheel bearing? Try jacking up the car, and spinning each wheel by hand, see if you hear, or feel anything.
Old Sep 13, 2016 | 01:46 PM
F15DOC's Avatar
Don't think its a wheel bearing, I would have heard it when she drove by.
Old Sep 13, 2016 | 02:32 PM
Cee Jay's Avatar
Sorry; you'd hear that clunking if the prop shaft CVs were gone, and possibly if the diff/ring and pinion were trashed as well as the half-shafts.
Old Sep 13, 2016 | 02:36 PM
Chaos236's Avatar
ON the 100 models that noise can be a shock mounting point.
Old Sep 13, 2016 | 03:20 PM
F15DOC's Avatar
So how would you go about figure out what it is?
Old Sep 13, 2016 | 04:22 PM
kj07xk's Avatar
How fast do you need to be going to hear/feel the clunk?
Maybe lost a wheel weight? And now have an unbalanced wheel?
Old Sep 13, 2016 | 04:29 PM
F15DOC's Avatar
Definitely not wheel balance, it is noticeable at all speeds, more pronounced at higher speeds, at a regular interval, worsens when off the accelerator.
Old Sep 14, 2016 | 06:16 AM
kj07xk's Avatar
And if you shift into N?
Old Sep 14, 2016 | 09:00 AM
Bobioknight's Avatar
Mine started clunking yesterday. Like something was rolling around in the trunk behind rear passenger seat. Mine is intermittent.
Old Sep 14, 2016 | 10:20 AM
britannia's Avatar
Remember always check simple things first! shock mounts, muffler system, ujoints (jack up rear end; check for play in drive train) run engine and listen; always use axle stands for safety!!!
On & off throttle may help you hear something amiss & where.
Good luck , Adrian
Old Sep 16, 2016 | 08:41 AM
buddhaboy's Avatar
Had same issue/sound on my Beemer. More likely a rear axle than the driveshaft, and if it is do both now as you will be doing both anyway.
Old Sep 16, 2016 | 07:27 PM
Fstbmw1's Avatar
Once you do your due diligence, shock mounts, loose exhaust hangars etc and you find all to be tight, or not worn, then I would say its something in your driveline.
zzjakect
Sep 6, 2016 05:43 PM
YYZ
Sep 4, 2016 10:56 AM
Howie
Sep 1, 2016 07:08 PM
Tink
Aug 31, 2016 07:41 PM
zzjakect
Aug 29, 2016 10:42 AM
