Help replacing conv sliding cover
Old Nov 13, 2019 | 01:18 PM
badicedog's Avatar
Default Help replacing conv sliding cover
Hi, off to next project. I don’t know the name of this part. It’s the sliding plastic cover that extends when the convertible top is stowed. I remember a tread of this about a year ago but could not find it. If anyone has experience with this repair, your input is very much appreciated.
Old Nov 13, 2019 | 01:38 PM
Canadacat's Avatar
I had this happen to mine it jumped track and broke string. If shouls move smoothly back and forth if it doesn't you have to manually with your hand put it back in the right track. I then tied the string together , think I used a fishing swivel and hooked it back on the bolt. You can see this if you stop your top when putting it up halfway.Fiddle around with it and look at the other side when your top lid is halfway up to see what it looks like.
Old Nov 13, 2019 | 08:27 PM
Stuart S's Avatar
The downloadable Workshop Manual in the "sticky" thread at the top of the first page of this Forum may be helpful.
Old Nov 17, 2019 | 03:44 AM
_jagart's Avatar
That should help you
Old Nov 20, 2019 | 09:26 PM
qcktvr's Avatar
Hi, I had this problem in May 2017 and started a thread:
Conv. rr qtr trm sliding panel questions..
hope you can find it...
The repair went well and cost only time, it is a poor design and our roof usually stays down, but it does still work ok
Good luck
WisconsinDan
Jun 9, 2015 05:31 PM
mog-guy
Jun 21, 2014 02:49 PM
Windycityx
Jul 2, 2013 07:41 PM
OhioXK
Apr 30, 2011 06:20 PM
WGS
Jun 11, 2010 10:48 AM
