humming noise and vibration when coming to a stop
Old Mar 16, 2023 | 09:55 AM
dynamohm's Avatar
Default humming noise and vibration when coming to a stop
Hi ,
Just joined this forum . I see lot's of great information . I recently purchased a 2011 XK . My last Jaguar was a 2006 XJR great car . My question is when I am coming to a stop at about 5 MPH I start to hear a humming noise and feel a slight vibration in the steering wheel . To me it sounds like the fuel pump but doesn't make sense as soon as I take off it goes away. Maybe this is normal. Any input would be appreciated . Thanks in advance
Old Mar 16, 2023 | 10:56 AM
RichardS's Avatar
I would think that vibration through the steering wheel at very low speeds is more likely to be the power steering pump. Is it present when the car is stationary? If so, you might be able to lift the bonnet and hear whether it is coming from the PAS pump area.
Richard
Old Mar 16, 2023 | 11:04 AM
Cee Jay's Avatar
Is your noise speed-dependent? I first though front wheel bearings.
Old Mar 16, 2023 | 11:29 AM
dynamohm's Avatar
It starts when slowing down to a stop at around 5MPH and continues when stopped and idling then goes away the moment I take off >
Old Mar 17, 2023 | 04:53 AM
JonWat's Avatar
So, pull up to a stop & leave it in drive, pull on the handbrake, open the bonnet & try to determine where the noise is coming from.
If the noise stops when you take your foot off the brake then get an assistant to drive it so you can open the bonnet & listen for it.
Old Mar 17, 2023 | 04:58 AM
RichardS's Avatar
Just don't stand right in front of the car when the assistant starts to drive it. 😲
Old Mar 17, 2023 | 11:53 AM
Stucciarello's Avatar
The big advantage of having a car with a hood that opens from the back. Just watch the toes and the mirror.
vincent661983
Jul 27, 2020 03:58 PM
Lazarus Young
Oct 15, 2018 01:38 PM
justenough
Jul 3, 2017 03:33 AM
nobodyspecial
Aug 5, 2015 03:20 PM
rpeppers
Jun 17, 2008 02:55 PM
