HVAC Blower Motor Not Turning?
Old Aug 31, 2015 | 05:15 PM
GreyXK's Avatar
Default HVAC Blower Motor Not Turning?
There is a small soft rubber circle in the center of the round bottom of the black plastic fan unit under the glove box. Press upward on it gently with the Climate Control on via touch screen and the *** turned to max (11?) - not just punching "Auto". May, or may not, work at least temporarily on a blower unit that is suffering/has suffered from the dreaded AC drainage problem. It's voodoo - please don't request explanation (I'm not around that often) it just works for mine. At least try this before tinkering with the control unit or motor itself. (I think it slightly raises the spindle/axis/brushes for better electrical contact to get it rotating. Or dislodges rust? It could be that water damage has adversely affected functioning. Electrical engineering was not my major.) Good luck.
Safari
US Central
Sep 21, 2015 09:34 AM
vicom
Sep 17, 2015 03:32 AM
explorer364
Sep 11, 2015 05:44 PM
Saturbo
Sep 8, 2015 07:35 PM
XJsc-guy
Sep 2, 2015 11:43 AM
