Info Center Back Light
Old Oct 22, 2023 | 09:26 AM
Hockey_Steve's Avatar
Default Info Center Back Light
The info center on our XK now has a red back light that showed up a week or so ago.
Not sure of the cause, but everything still works.
Old Oct 22, 2023 | 06:54 PM
jahummer's Avatar
Display's done, if you're good with eletronics and soldering, you can do it yourself, otherwise new cluster from main dealer.
Old Oct 22, 2023 | 07:19 PM
McJag222's Avatar
Originally Posted by jahummer
Display's done, if you're good with electronics and soldering, you can do it yourself, otherwise new cluster from main dealer.
Is the display available as an individual unit to solder in?
Old Oct 22, 2023 | 09:33 PM
jahummer's Avatar
Not directly from Jaguar, but another member’s done it recently using a working display removed from a used cluster.
Old Oct 22, 2023 | 11:06 PM
McJag222's Avatar
Too bad it's not source able from an electronics supplier somewhere out there.
Old Oct 22, 2023 | 11:13 PM
Cee Jay's Avatar
Changing the entire gauge panel would be a nightmare, with all the programming and such required, and then the VIN would have a permanent Mismatch code.
Maybe try to find a specialist somewhere, and possibly have just the display swapped from a replacement panel.
Old Oct 23, 2023 | 06:26 AM
justinhill's Avatar
Now, if you'd started this thread saying that you'd upgraded the info centre to have this really cool graduated red tint, there would probably have been people wanting you to show them how to do it to their cars...
Old Oct 23, 2023 | 06:32 PM
Sean W's Avatar
https://www.jaguarforums.com/forum/x...needed-263087/
Old Oct 23, 2023 | 07:33 PM
McJag222's Avatar
Ebay has center consoles :
https://www.ebay.com/itm/22499381074...86.c101224.m-1
Old Oct 23, 2023 | 08:22 PM
McJag222's Avatar
Quote from the other thread re-display swap:
Originally Posted by MudDog
Hey Hummer guess what . Its plug and play !!! no soldering needed.
Let me say this.
I have CONFIRMED the statement that you CAN NOT direct swap the instrument cluster. Even if the replacement is in the same VIN Range.
I obtained a nice looking full cluster from a VIN B11xxxx mine is B15xxxx. Direct swapped. Car would not even come on. Swap back, all is fine. WOW.
Im sure somewhere in somebodys mind this makes sense. The BCM and PCM should hold the important info. Why in the world lock out the car with a simple Readout Swap.
Any Way.
After disassembling the donor Cluster , removing the center screen and installing it in my cluster, took 30 minutes. It WORKED I can actually see the Center Screen , Color ME happy
OLD
NEW
AND YES , the Speedo Needle is 5 mph Off , Ill go In and reset it later. Im just tickled this improvement is off the scale
Old Oct 24, 2023 | 06:46 AM
guy's Avatar
guy
The replacement is missing the electrical tape patch….
Cheers!
bigdollar
May 24, 2011 09:46 PM
cadrad
Nov 7, 2009 02:03 PM
chapman2424
Sep 30, 2008 09:21 PM
rivs
Nov 7, 2007 12:08 PM
