Audio gone crazy
Today the audio system took on a mind of its own, the satellite was trying to update and at some point channel got hung up. Would not do anything for changes and controls were acting strange. When I turned off ignition, audio kept playing, could find no way to turn off, was getting ready to pull fuses, but decided to just lock vehicle and see what happened. Audio kept playing, but after short while, shut down.
when I started again, all seemed OK.
Any ideas? Did the update software cause a strange click and then got reset, leaves one with uneasy feeling, my XKR is 2008 and I have used as a daily driver in good weather for last 12 years, my AM does not currently function but I am not AM user, thinking my splitter may be bad,
This was very strange!
Well I’ll be…
Took the car to the car wash.
sirius update started.
Then all my audio crapped out.
Try turning on and off and nothing.
Got to the car wash. Turned off the car. Got out. Locked and unlocked it. Then got back in.
And she’s back to behaving properly.
On my return home I’ll look for thrown codes.
Is it possible that the Sirius update is the problem? If it's a code update, these are old hardware -- could be the update is loading code built for a different unit or different year, or loading something because your year is obsolete. Reach out to sirius tech support and find out the status of you hardware support.
Or is the "update" just the satellite search it normally does? In which case the hardware or antenna may be flaky. Pull the unit in the trunk and reseat all the connectors after spraying the with a bit of electronic contact cleaner. And, of course, don't spray the MOST connector....
We don't have such things in Europe.
We Have DAB+ ( Digital Audio Broadcast) and it's free. It's supposed to replace the old Hertzian radio network.
[QUOTE=Howell;2688203]Today the audio system took on a mind of its own, the satellite was trying to update and at some point channel got hung up. Would not do anything for changes and controls were acting strange. When I turned off ignition, audio kept playing, could find no way to turn off, was getting ready to pull fuses, but decided to just lock vehicle and see what happened. Audio kept playing, but after short while, shut down.
