Infotainment system
Old Jun 21, 2021 | 08:10 AM
JagV8's Avatar
Cool car, in any case - sorry to hear it's not working right now!
Old Jun 21, 2021 | 08:33 AM
chris neil's Avatar
Is there any chance you could post a link so I know what I am looking at?
Old Jun 22, 2021 | 12:58 PM
Sean W's Avatar
If you go the OEM, SDD (Symptom Driven Diagnostics), here is a list of approved devices. As far as which version of software you need, you can use version 118 - 123 and you'll be fine for you model year. Those versions also contain IDS (Integrated Diagnostic System) which was the earlier version that Jaguar used and some find it easier to use. The software version numbers increase as new models were added. Not an issue for you. Get the software from someone here on the forum. Mine's customized so I can't shared it, otherwise I'd be happy to. I think Graham makes downloads available to users. I believe a few guys here are happy with the DA Dongle and cable.
Also, be aware you need to have the car on a charger while doing anything with SDD, except maybe reading DTC's. I'm not talking about a 10 volt car charger. See attached. Midtronics is the one Jaguar recommends but you and find others for less $. I use an Actron.
I agree with 80srule that given your issues, you'll want SDD vs iCarsoft or Foxwell or Autel units. They won't give you the full 7 digit DTC, just the first 5.
File Type: pdf
Old Jun 22, 2021 | 02:36 PM
Cee Jay's Avatar
Old Jun 30, 2021 | 01:56 PM
Philip149's Avatar
Originally Posted by chris neil
i am having the issue a lot of people report of an intermittent screen; however, what I notice is that the radio will not turn on and the aerial mast does not extend.
Are these related problems or seperate issues?.
I also had the dead button issue last week where the care would not start and was completely dead. the only thing I had was the engine management light illuminated.
the car was recovered last tuesday by an RAC sub contractor and is still sitting in the secure lock up today _ RAC are not going to enjpy our chat on Monday!
Can anyone recommend a code reader
Thank you
Chris
Hi Chris I suffer similar problem the radio either stays on even after i have left the car and locked it or it wont come on at all . but I have an extra problem with drivers door window will not drop to close door from inside have to lower window and use door handle to close it .this is all intermittent and can go weeks without any of these faults occurring . seems wet weather may bring it on more often . did you find out what was causing your problems?
Old Jul 1, 2021 | 03:53 AM
chris neil's Avatar
Hi
Well i was 100% sure it was not the battery as i checked it and it was 12.7 V and when the recovery guy came he agreed it was ok. It was sat with the recovery firm for 6 days before they moved it to a local independent Jag specialist near where I live so I have no idea what happended while it was there. Except to say they got it going and drove it onto the trailer when they brought it back even though it was dead as a dodo when they initially revovered it.
So, it had a new battery and the garage re-set everything including a windown reset and cleared all faults with their SDD reader and so far so good.
Sorry I cannot be of more help
Old Jul 1, 2021 | 04:06 AM
chris neil's Avatar
Hi Cee Jay
Well as much as I thought it wasn't the battery it was!
The previous owner had a new battery fitted in 2019 and I don't think it was a particularly good one.
There is an independent Jag specialist near where I live where the car was recovered to and they have fitted a new battery and touch wood, no further issues - long may it continue.......
Old Jul 1, 2021 | 08:38 AM
  #28
80sRule's Avatar
Nice that it was cheap! Enjoy the ride!
VancouverXJ6
Oct 24, 2017 05:12 PM
sorapp
F-Pace (X761) / C-X17
Apr 12, 2017 07:58 PM
RobinGa
Feb 22, 2016 07:19 AM
jahummer
Dec 25, 2011 11:16 AM
woodpuppy
XJ40 ( XJ81 )
May 19, 2009 10:57 PM
