Inner Mirror Cover C2P2755
Does anyone have a source at a non-stupid price for the inner mirror cover (tweeter housing, drivers side)? I broke mine a while ago and now that I went looking for them online I can't find one under $200. Seems like it should be a $35-40 part.
https://www.sngbarratt.com/us/#!/Eng...9-e2f703179d29
I believe this is one from 2010 model but should work, no?
For 2010+ parts are C2P10275 and C2P10274 might give you some more options....
I had a similar issue, though mine still has some of its tabs so it seems to stay in place. While looking for options, I noticed the later chrome-ringed version, which TexasTraveler already linked to, seems to be about half the price for no obvious reason! They also look nicer, though obviously you'd need two.
I read a thread here some time ago which confirmed the later part should fit in place of the earlier part, as a member said a dealership mistakenly fitted the early part to his later car.
Had the same issue with my F pace and I believe they are the same size as the ones in my XKR
cost $50 each
part number T4N3828
Call:Clifton Fomby
Parts Department
Jaguar Land Rover Columbia
803.731.7493 Ph
866.560.6461 Fax
fomby@jaguarcolumbia.com
cost $50 each
part number T4N3828
Call:Clifton Fomby
Parts Department
803.731.7493 Ph
866.560.6461 Fax
cost $50 each
part number T4N3828
Call:Clifton Fomby
Parts Department
803.731.7493 Ph
866.560.6461 Fax
cost $50 each
part number T4N3828
Call:Clifton Fomby
Parts Department
803.731.7493 Ph
866.560.6461 Fax
daboss085
Nov 1, 2012 05:13 PM
Estilian
May 3, 2012 01:44 AM
stephen11962
Aug 3, 2010 08:38 PM
