Issue starting ... brake pedal
Old Jan 12, 2022 | 07:41 PM
ejp's Avatar
ejp
Default Issue starting ... brake pedal
Starting the 2007 XKR occasionally I get a lot of brake pedal and the car won't start. Second or third time the pedal seems to give a bit and the car starts fine. I'd be fine overriding the brake to start ... but I'd rather it worked as it should ... I have a new AGM battery it is certainly not a battery cranking problem ... there's enough juice now to crank the motor for a WWII fighter plain, some gremlin to deal with the brake, the safety switch, something ... any thoughts?
Old Jan 13, 2022 | 03:05 AM
Stuart S's Avatar
If you inadvertently pump the brake pedal, it will feel high and rock hard. The high pedal makes it difficult to make contact with the starter switch, so you'll have to stand on the brake pedal with both feet when you press the start button.
The simple solution is to press the START button BEFORE you step on the brake pedal.
Note that other manufacturers require that you step on the brake pedal before you press the start button. Jaguar works either way, but I find that my car starts much quicker when I press the start button before stepping on the brake pedal.
My Jaguar service adviser recommended this, notwithstanding the Owner's Handbook to the contrary.
Old Jan 13, 2022 | 06:49 AM
kj07xk's Avatar
Old Jan 13, 2022 | 09:49 AM
ejp's Avatar
ejp
Originally Posted by kj07xk
High and rock hard ... I remember those days ... I digress, I've always turned the vehicle on and let the fuel pump run before engaging the starter ... I had a 2011 5.0 XKR and an 2007 ragtop, did not exhibit this issue. Yesterday I actually got out of the car and started anew, as I had tried a good five or six times to get the vehicle started ... been running it hard with the dense cool air we've had here in Ohio ... thought maybe it was reluctant to go out and get thrashed about ... 🤣
It's a quirk ... I'd rather have it right, but every Jaguar I've owned has been quirky ...
Thanks!
Old Jan 13, 2022 | 10:32 AM
Stuart S's Avatar
Originally Posted by ejp
High and rock hard ... ​​​​​​​
Thanks!
You're a newbie ... that's what the button on the bottom right corner is for.
Old Jan 13, 2022 | 12:03 PM
carealtor's Avatar
Occasionally I find my brake pedal to be hard when I go to start it. This is ALWAYS after not driving it for several days. My assumption is that I have a very small vacuum leak and the brake booster vacuum leaks down over time.
kiddhan625
Jun 3, 2021 04:55 PM
sogood
Apr 28, 2021 03:56 AM
Tomwhite
Mar 15, 2021 07:24 AM
whedonum
Feb 24, 2020 06:03 AM
DB6
Jun 21, 2011 11:21 AM
