Left side indicators not working.
Old Mar 8, 2024 | 10:10 PM
KDjag's Avatar
Default Left side indicators not working.
Just purchased this 2008 xk coupe. very cheap for good reason. Has some electrical gremlins i'd love to get sorted out. It started with the left side indicators not working, as well as the right high and low beam not working. I've fixed the ground on the right wheel arch, and upon inspection realized one of the ballasts were corroded so i replaced it. Now both headlights work, low and high beam, however none of the left side indicators work. front, side, or rear. I did a soft reset (connecting positive and negative terminal together) and when i activated the left indicator i saw all left indicators light up for about a second, then switch off immediately. The problem persists with the left indicators. I can only get them to work for about one second after a soft reset, after that, nothing. Any pointers in the right direction? Is there a different ground I should be worried about?
Old Mar 9, 2024 | 08:04 AM
McJag222's Avatar
Two different grounds for the lh indicators. Could be an instrument cluster issue - low battery conditions can give some weird effects with the cluster.
LongJohn
Aug 29, 2023 01:27 PM
XJeej
Feb 17, 2023 02:37 PM
Om28v
Oct 5, 2019 04:26 AM
dirk_BE
Aug 29, 2018 09:06 AM
Gufo62
Dec 1, 2017 03:58 PM
