Location of Sirius Satellite Receiver - 2010 XK/XKR
Old Feb 5, 2015 | 05:40 PM
tommyd's Avatar
Default Location of Sirius Satellite Receiver - 2010 XK/XKR
Where is the Sirius Satellite Receiver located in a 2010 XK/XKR?
Old Feb 5, 2015 | 07:24 PM
Ceckman's Avatar
No expertise here - but I would assume that it is built into the radio unit. In other words - it would simply be "all one piece" as opposed to having a secondary receiver dedicated to SAT reception.
I believe the "shark fin" antenna is SAT related (to best of my knowledge).
Now I will sit back and be educated.
Old Feb 5, 2015 | 07:56 PM
u102768's Avatar
I think it sits above the navigation unit in the trunk.
Old Feb 6, 2015 | 12:09 AM
Ngarara's Avatar
Correct - same location for satellite radio or European digital terrestrial radio (DAB).
Old Feb 6, 2015 | 06:47 AM
bobdr1's Avatar
that is correct, it is in the trunk above navigation, you can pull it out after removing the 3 screws that hold it to the bracket to look at the back of it which has the sat. ID number. You don't have to undo any of the wire connections to do this, then just push it back in, redo the 3 screws and call sirius to start activation.
Old Feb 6, 2015 | 07:20 AM
jagtoes's Avatar
Am I missing something or doe the ID not show up in some cars. When I press the Sat button the ID comes up on my screen as I am nor subscribed. Is it different on different year cars. 2012 XKR
Old Feb 6, 2015 | 12:45 PM
tommyd's Avatar
Thanks everyone but where in the trunk is the navigation/Sat Receiver located?
Old Feb 6, 2015 | 01:46 PM
BlackX300VDP's Avatar
First make sure the top is all the up.
Open the trunk and remove the luggage separator. Retract it in to the reel then gently twist the whole thing so that it releases from its mountings. Remove entirely so it is out of your way.
look at the black carpet panel that was covered by the luggage separator.
Remove the four black hook things by unscrewing them.
Remove the black carpeted panel.
This will reveal the battery on the left and the navigation and satellite unit on the right. The SAT unit sits above the NAV unit and once unscrewed, you'll see the SIRIUS ID label.
Why are you curious where it is?
Old Feb 6, 2015 | 02:08 PM
tommyd's Avatar
I just purchased a 2010 XKR and wanted to activate a 2 month trial for Sirius. When I called Sirius XM customer support they said there was no radio receiver registered with the vin associated with my car. Also, on the SAT screen it does not display a Sirius ID. I want to determine the Sirius ID from the radio or see if there is a problem with the connection to the radio or if there is a radio installed at all.
Old Feb 6, 2015 | 02:42 PM
Gotcha.
I've seen those modules fail often so it could be there but not working.
Good luck. Be careful with the luggage separator. If it doesn't go back into place properly, the top won't work.
Old Feb 11, 2015 | 01:06 PM
04XK8Conv's Avatar
Although the work I did was on my 07, much of this should be relevant to the 2010. At the very least you can see what the SDARS module looks like. Even though I have a coupe I was using my mom's convertible as a reference. Hopefully this helps.
https://www.jaguarforums.com/forum/x...install-96855/
Rivguy
Dec 4, 2020 07:55 AM
Dz1rfj
Jul 17, 2018 10:29 AM
thechaosmachine
Sep 23, 2015 10:03 PM
'05 Gold XJ8L VDP
Sep 18, 2015 07:15 AM
Dz1rfj
Sep 16, 2015 03:44 PM
