locking wheel nut
Old Feb 24, 2025 | 03:43 AM
rflorey's Avatar
Default locking wheel nut
I have a puncture and cant remove the locking wheel nut off my 2007 XK. the key i have doesn't seem to fit. Any help would be most appreciated
Old Feb 24, 2025 | 03:56 AM
RichardS's Avatar
Does the key fit any of the wheels? Does the key look right, more or less?
If it's clearly the right key, it could be just corrosion or distortion that is stopping the fitment and you can use an abrasive to clean things up or just hammer it on.
If it's obviously not the right key, it sounds as if you need to call a Jaguar dealer to see what they say or a garage as DIY removal, whilst possible, requires some experience to avoid damage to the wheel.
Richard
Old Feb 24, 2025 | 06:56 AM
sony2000's Avatar
Not the answer you are expecting, but buy 4 more nuts and plan to get rid of the locking ones. After a while they become problematic and are not needed.
Old Feb 24, 2025 | 09:34 AM
Cee Jay's Avatar
Originally Posted by RichardS
............ or just hammer it on.
............or a garage as DIY removal, whilst possible, requires some experience to avoid damage to the wheel.
Richard
Do this ^ ^ ^ ^ ^
Acquire a cheap deep socket of a size that doesn't quite fit over the outside of the lock nut. Smash it on and remove the entire thing. You will damage the socket and nut, so be prepared to throw it away while stuck together.
Old Feb 24, 2025 | 10:07 AM
Stuart S's Avatar
And pray 🙏🙏 that you don't snap the wheel stud. The OEM lug nut is 19mm.
Here's how to do it:
NAPA: How to Remove a Seized Lug Nut
Old Feb 24, 2025 | 10:58 AM
sony2000's Avatar
At the Tire Shop the inhouse mechanic always used a cold chisel and hammer for impossible nuts.
Old Feb 24, 2025 | 01:37 PM
Sean W's Avatar
Tire shops also have a lot of different lock nut sockets for situations such as yours. There a four tire shops with 5 miles of my house. If it were me, I'd stop at each one just in case.
Old Feb 24, 2025 | 03:33 PM
Cee Jay's Avatar
You guys forget, his tire is punctured. I ASSUME that the tire is either quickly deflated or quick enough to preclude driving the vehicle. Nobody wants to damage a wheel that costs $1000 to replace (guess).
Old Feb 25, 2025 | 03:13 AM
RichardS's Avatar
Not me, 'cos I'm assuming that he'll simply call a mobile mechanic if the tyre does not stay up long enough to get the car to a fixed one.
Richard
Old Feb 25, 2025 | 04:48 PM
Cee Jay's Avatar
You guys forget, his tire is punctured...
Richard
Me assuming again, but I figure that if dude's capable enough to attempt to remove the offending wheel/tire to have it repaired, he'd be way more than capable to attempt simple at-home fixes before shelling out $250 to have some other guy come and do basic tool usage for him.
bogtrotter
General Tech Help
Aug 16, 2022 04:43 AM
Pristine97XK8Convertible
Jun 14, 2018 02:11 PM
fourbyfourbyfar
Jun 23, 2014 08:09 AM
mike213735
Nov 1, 2013 10:11 AM
