Long Term Storage Question
Old Sep 2, 2021 | 05:29 AM
XKRAU's Avatar
No one mention this, but I would to put the car on jack stands and raise it off the floor. If you can't do that get some marine grade carpet and place them on each tyre. Pump up the tyres to their maximum pressure, usually 44psi so they don't deform and dry rot. Car / dust cover keeps it nice and clean.
I personally wouldn't bother about cranking it over every couple of months. Just give it an Italian tune up when you ready to drive it again.
Battery tender helps. I've got one which works with lead acid, AGM and lithium batteries for my MC. The tender also act as a secondary battery source so if you disconnect the main battery it acts as a backup battery so you don't loose the memory settings etc.
Old Sep 2, 2021 | 02:45 PM
mosesbotbol's Avatar
Originally Posted by jons
unless i am missing something, if you do this repeatedly while in storage without ever running the vehicle, you will have fuel in the oil pan, oil will drip back down from the top end after a week or so anyway, and each time you turn it over the well-washed rings will scrape and whatever oil you do pump back up will be thinner. at least the injectors won't gum up, hey?
Modern oils stick the cylinder for a very long time. You can tear apart an engine that hasn't been started in years the there's still oil along the cylinder. I would not turn over the engine just for the heck of it. Some collectors want their cars rolled around the garage to avoid unnessary starts (on older cars).
Old Sep 3, 2021 | 12:07 AM
peterv8's Avatar
I've had my MG and Jaguar in winter storage for 11 years and have never started the engines in the winter. Same with my motorcycles I had when I was younger, I just cranked the engine a few seconds before I started them in the spring. Never used gasoline stabilizor in any vehicle either and they all ran fine in spring!:-)
George Abitbol
Jan 19, 2021 09:58 AM
jbmi
Oct 27, 2020 09:36 PM
khsjsilver
Sep 28, 2017 03:28 AM
simongulliver
Jun 24, 2016 06:31 PM
jehart49
Mar 28, 2015 11:00 AM
