Low battery warning message
Old Nov 23, 2024 | 09:34 AM
alanroberts50's Avatar
Default Low battery warning message
When I first get into the car, if I spend time messing around with the nav/settings etc I get a warning message on the screen to the effect that the battery is low and to switch on the engine otherwise the screen will turn off automatically! Is it referring to the main vehicle battery? Does it mean my brand new 100a battery really is low?
Old Nov 23, 2024 | 09:42 AM
Cliffords's Avatar
Deleted
Old Nov 23, 2024 | 10:28 AM
Cee Jay's Avatar
Your car just told you your battery is low.
"Some Time" messing around... over a few minutes will do that every time. There are a LOT of modules running, even with just a door open.
The best advice would be to fully CHARGE your battery using an actual battery charger. Not a maintainer, not a trickle charger. Then don't use the electronics without the engine running for more than a minute.
Old Nov 23, 2024 | 03:40 PM
sov211's Avatar
Yes, the main battery. That is exactly what it means, and if you do not recharge the battery (fully) you are likely to get different warning lights or malfunctions showing up. Full battery voltage is crucial for these cars (and all modern module-laden cars).
Historical
Feb 25, 2022 01:56 PM
Marthamtz
XF (X260)
May 19, 2020 01:51 AM
domino_z
Nov 18, 2016 05:01 AM
philhef
Aug 18, 2013 10:50 PM
VapourTrail
Feb 25, 2013 08:51 AM
