Low coolant temp code
Old Feb 4, 2025 | 07:47 PM
Fred1996's Avatar
Default Low coolant temp code
So yesterday and today I got an engine light which turned out to be a low coolant temp code.
Using my reader it showed temps in the 150-180 degrees range tonight when driving but then jumped to 190s and 204 at idle. When I reset the code it won't come on until the next day. 150 degrees coolant temp seems not possible. (outdoor temps 55 degrees)
Using a reader the temp data doesn't look right. It hold the same reading within a tenth of a degree for long periods when all the other data points float around a few tenths constantly.
Based on other threads it looks like a sensor starting to go bad.
BTW:I never have battery issues or a dead battery even after sitting for a while.
Any advice appreciated.
Old Feb 4, 2025 | 08:23 PM
Cee Jay's Avatar
Is your coolant fully topped off and purged?
Your coolant temperature sensor may be faulty if your fluid is full.
Old Feb 5, 2025 | 03:35 AM
RichardS's Avatar
As said, most likely to be a failing sensor just just check that the connector has not become loose or contaminated first.
Richard
Old Feb 5, 2025 | 06:22 AM
guy's Avatar
guy
But I would never rule out an airlock…
Yes 150 is low.
Old Feb 7, 2025 | 03:39 PM
ericmcn's Avatar
Cooalnt on my XKRS is alwways around 95C - 203F when warm and does not change much if at all during driving, 150F is far too low as above
Old Feb 8, 2025 | 03:09 AM
Woo5ie's Avatar
Probably a broken thermostat.
The rubber seal breaks and prevents the stat from closing.
very common.
Could also be the internal housing stat flange has broken.
not too bad to check
Ryan6864
Dec 23, 2024 08:48 AM
Kuddlesworth
Dec 18, 2021 01:41 PM
Dconway
May 8, 2019 06:44 PM
twmotox
Aug 11, 2017 12:07 PM
Wingrider
Mar 7, 2017 08:24 PM
