Low coolant temp code
So yesterday and today I got an engine light which turned out to be a low coolant temp code.
Using my reader it showed temps in the 150-180 degrees range tonight when driving but then jumped to 190s and 204 at idle. When I reset the code it won't come on until the next day. 150 degrees coolant temp seems not possible. (outdoor temps 55 degrees)
Using a reader the temp data doesn't look right. It hold the same reading within a tenth of a degree for long periods when all the other data points float around a few tenths constantly.
Based on other threads it looks like a sensor starting to go bad.
BTW:I never have battery issues or a dead battery even after sitting for a while.
Any advice appreciated.
