Low mileage filter maintenance
Old Nov 16, 2021 | 05:24 PM
bocatrip's Avatar
Default Low mileage filter maintenance
After 8 years of ownership and 14,000 miles, the only maintenance I have been doing on my 2010 XK has been yearly oil changes and a brake flush. My coolant was changed a few years ago with the water pump replacement. Is there any need to change the engine air filter and cabin a/c filter? I would assume the cabin filter should be changed just for it's age. Any suggestions would be greatly appreciated.
Old Nov 16, 2021 | 07:03 PM
randyb's Avatar
Cabin filters should be changed every two years, your air filters are good.
Old Nov 16, 2021 | 07:53 PM
Cee Jay's Avatar
Pull the cabin filters, see if they need a vacuuming. Reposition after the cleaning!
Engine air filters are one quick peek. There is a lot of surface area, so you're probably good IF you had clean filters when your 14,000 miles started.
Old Nov 17, 2021 | 10:39 AM
bocatrip's Avatar
Thanks everyone. Are the cabin filters easy to replace? Is it a DIY replacement?
Old Nov 17, 2021 | 10:53 AM
Very easy and no tools required:
Frequency of change depends on a combination of air quality and mileage. I keep a spare and change as required rather than slavishly following a time elapsed schedule.
Old Nov 17, 2021 | 11:13 AM
Cee Jay's Avatar
I've changed my cabin filter once. I usually have the top down and nothing on except maybe the cooled seat. I don't use heat or A/C very often at all.
Old Nov 18, 2021 | 08:07 AM
jahummer's Avatar
Intake filters likely good, mine looks nearly new after 40K+ miles, really dependent on how much dust they are around, in a desert likely more frequently than anywhere else. Cabin filters can get musty so I change them every year, easy to do and little cost. Coolant good for about 5-6 years, brake fluid varies on use and humidity, I've had some last 1-2 years and some last as long as 5 years. I used a fluid tester which detects the percentage of water in fluid as brake fluid is hydroscopic and it's water which not only reduces the effectiveness of the fluid but also increases the chance for oxidation, rust, formation within the brake system. Transmission fluid varies based on use but a good rule of thumb's to replace around 50-60K miles. Power steering fluid should also be changed around 5 years or smell test it.
Old Nov 18, 2021 | 10:08 AM
bocatrip's Avatar
Thanks everyone for all the great advice!
Jagst
Feb 20, 2016 05:25 AM
Jgmc
Dec 21, 2013 03:56 AM
jagosaurus
Feb 8, 2013 05:10 PM
bgilgall
Mar 8, 2010 08:28 AM
IrishXtype
Mar 5, 2010 03:42 PM
