Lower grille interchangeability
Old May 22, 2024 | 04:21 PM
David993S's Avatar
Default Lower grille interchangeability
Is the front lower grille on the '07-09 XKR the same as on the '10-11 XKR, i.e. are they interchangeable? Or a different shape/mounting? Is the '07-'09 XKR-S different in shape from same year XKR?
They look the same to me in photos, but sometimes there are subtle differences.
Thanks..
Old May 22, 2024 | 04:45 PM
Stuart S's Avatar
The easiest way to know with certainty is to search an online ORM Jaguar parts seller and see if those parts for different model years have the same Part Numbers.
Old May 22, 2024 | 05:30 PM
David993S's Avatar
They have different part numbers, but look identical. That's why I was asking. Even for an '07 - '09 XKR there are two grilles with different part numbers - one for cars with block heater and one for cars without block heater. But both fit. Go figure.
Maybe a simpler way to ask: is the lower grille opening (size, shape, dimensions) on an '09 the same as a '10?
Old May 23, 2024 | 03:56 AM
justinhill's Avatar
I wouldn't count on it. The front end was re-worked somewhat for the 5.0 version of the car.
Old May 23, 2024 | 06:52 AM
David993S's Avatar
Thanks Justin. That's what I needed to know.
Cheers.
yidal8
May 14, 2019 09:42 PM
kenatofc
Mar 28, 2016 02:53 PM
8bit
Apr 29, 2015 07:23 PM
Padrino
May 28, 2013 12:24 PM
handychgo
Nov 7, 2008 11:57 PM
