Lug nuts
Old Nov 3, 2018 | 08:32 PM
qcktvr's Avatar
Toyota oem nuts are also wrapped in SS, they also fail and the reason for the availabe aftermarket solid steel plated nuts as there are SO many more of them out there than Jaguars.
Not a problem for many of us, but the plating quality on the cheap nuts is poor, seen cracking and rust stains on our Toyota's, have a set ready for the XK "when" the wheels come off one day.
By the way, 19mm is .748ins and a 3/4in 6pt socket will be just fine...
Regards
Old Nov 4, 2018 | 09:09 AM
kj07xk's Avatar
Then you should go with Lexus nuts (I thought they used the same on both brands, but apparently not). Both my current and previous Lexus cars had solid nuts, not wrapped.
Old Nov 4, 2018 | 10:41 AM
Stuart S's Avatar
Originally Posted by Ter11
I have a complete tool kit wrench set with all usual metric nut sizes. Thats what I used two weeks ago to remove my wheels with original lug nuts. Even if these toyo size lug nuts have a slightly different size I guess I just need the correct nut size for my wrench.
I, too, have a full set of metric sockets that I keep in my garage.
Just make sure that you have a breaker bar that fits those lug nuts in your trunk. Otherwise, you'll be unable to put the spare tire on when you get a flat.
If you don't already have a rubber-coated deep socket that fits your lug nuts, I recommend buying one and keeping it in your trunk together with a ratchet handle and extension. I also keep a torque wrench in the trunk. I bought the socket and torque wrench at Harbor Freight and recommend them. Once loosened with the breaker bar, the rubber coated socket protects the rim from damage and the ratchet handle makes quick work of removal and reinstallation. I also recommend keeping a 12 volt tire inflator in the trunk, in case you have a slow leak and don't want to put on the spare.
Be prepared!
Old Nov 4, 2018 | 11:33 AM
Ter11's Avatar
Thanks! Unfortunately my car was delivered w/o spare tire. So no chance for me at any rate to have a spare tire fitted on the road after a puncture. Therefore also I didn’t get a breaker bar nor any other tools for tire removal with the car - only the repair kit with 12v inflator. Hopefully will never need it!!
br
ter
Old Nov 4, 2018 | 09:02 PM
Stuart S's Avatar
I feel your pain! I, too, had no spare tire because my XKR has Alcon brakes. But I wasn't comfortable driving around for 2 years with the 12 volt inflator kit and no jack or spare tire. Here's how I was able to put a spare in my trunk with all the factory tools:
https://www.jaguarforums.com/forum/x...-brakes-67260/
You can do it, too. Because you have a 5.0L, you might not need the custom spacer that I needed to clear my rear Alcon rotors.
Byte Me
Jul 9, 2019 10:56 AM
texevora
May 6, 2019 10:07 AM
MikeofBonsall
Jun 29, 2017 12:19 PM
Vipercf
23
Jun 14, 2015 09:55 AM
