Luggage separator parts
Old Mar 10, 2026 | 11:12 PM
Leo Dalla Rosa's Avatar
Default Luggage separator parts
I have a 2007 jaguar xkr convertible and need to get luggage separator parts..maybe just the clips if that is all i need for my top to work. Anyone who knows please get back to me.
Old Mar 11, 2026 | 06:07 AM
bladerunner919's Avatar
Still the wrong forum! You need to be here: https://www.jaguarforums.com/forum/xk-xkr-x150-33/
Old Mar 11, 2026 | 07:21 PM
moved to the appropriate model forum
Old Mar 11, 2026 | 11:29 PM
kj07xk's Avatar
Holy crap, third thread with the same question!
Old Mar 12, 2026 | 12:08 PM
Canadacat's Avatar
Found this in the web. If I was in this position I would try to bypass.
Bypassing the Luggage Separator
  • Manual Override: To force a bypass, ensure the separator is completely removed from the car, which can sometimes allow the system to operate if the sensor is in a fault state.
  • Sensor Jumper: You can manually push the switch button on the left side of the trunk mechanism to trick the car into thinking the partition is in place.
  • Manual Top Operation: If the sensor is broken, you can close the roof manually by releasing the tonneau cover pressure valve in the trunk, though this does not fix the sensor.
  • Wire Jump: For a permanent bypass, a wire can be used to connect the wires (often red and brown) on the connector, signaling a "closed" status to the
Old Mar 12, 2026 | 03:40 PM
kj07xk's Avatar
Wherever the ‘web’ got this info, it’s terribly wrong.
Old Mar 12, 2026 | 04:23 PM
HealeyJag's Avatar
OK..
How is it wrong???
Old Mar 12, 2026 | 06:43 PM
kj07xk's Avatar
Originally Posted by HealeyJag
OK..
How is it wrong???
A. Removing the separator isn’t going to allow the system to operate.
B. There is no switch button to press.
C. The tonneau cover is released by a pull cable, and the top hydraulics have a pressure release valve.
D. Yes, you could wire a bypass. Not easy to get to, and placing a piece of metal in the track to trick the Hall Effect sensor is easier.
Old Mar 13, 2026 | 10:03 AM
HealeyJag's Avatar
Thanks for clarification...
felt the same..
but love to ask questions
Leo Dalla Rosa
Mar 11, 2026 04:27 PM
wpdoyle
Dec 3, 2021 06:51 PM
Mprimo
Nov 12, 2019 02:32 PM
Oh My NewYork
Jun 26, 2017 10:21 AM
